Results 1 to 2 of 2
Thread: Mixing ATF's? Mobil1 type?
    Mar 2004
    2001, Kaiser
    Those of you who use Mobil 1, which ATF do you use?
    Their website says both "ATF D/M" and "Multi Vehicle ATF" can be used to replace Dexron III. Which is better? What is the difference?
    Also, if you have previously used a different brand (i.e. Royal Purple) is it necessary to completely flush out all of the old fluid to avoid any possible problems from mixing incompatible fluids? Or can they be combined?
    I ask this because I have heard it is good to drain and fill (at 15K miles) in between doing a complete service (every 30K miles) when the pan is dropped to replace all of the fluid as well as the filter and gasket. Thanks in advance for any information on this.
    2001 Ebony 0177
    Even dropping the pan, does not get the couple of quarts of juice outta the torque converter. In most vehicles there is no way to drain it, so as long as you're using the proper type, mixing the small amount left, with the new stuff, won't present any problems.
  1. WHat type of oil should I use?
    By jheyson =) in forum VX Talk...
    Last Post: 04/16/2013, 12:00 AM
  2. Costco Coupon- $9 OFF MOBIL1 - 6 QTS.
    Last Post: 06/01/2010, 03:22 PM
  3. What type of LSD is in the rear?
    By haulin79 in forum VX Talk...
    Last Post: 06/26/2006, 08:14 AM
  4. what type of oil should i use?
    By V12BMW in forum VX Talk...
    Last Post: 11/03/2004, 06:37 PM
  5. Mobil1 Filter number?
    Last Post: 05/02/2004, 05:03 PM
