Results 1 to 6 of 6
Thread: New Option For Rear Sub !!!
    1999, Ebony Black, VX ,1976
    Looks like JL AUDIO is going to make a sub that may fit in the spare tire.
    Here are some specs.
    12TW5-4
    Nominal Diameter: 12 in. (300 mm)
    Continuous Power Handling: 300 W
    One-Way Linear Excursion (Xmax): 0.38 in. (9.7 mm)
    Voice Coil Diameter: 5.50 in. (140 mm)
    Nominal Impedance: Single 4 ohm
    Mounting Depth: 2.50 in. (63.5 mm)
    Recommended Sealed Enclosure: 0.63 cu.ft. (17.7 liters)
    Here is the link. JL AUDIO
    1COOLVX
    very cool.
    -biju.
    Aug 2006
    1999, Astral, Vehicross, 1619
    Quote Originally Posted by biju
    very cool.
    -biju.
    Those open several options for placement. Hmmmm.
    I am thinking one on each side behind the rear seat. shawn
    Mar 2005
    01 Ebony - #0379
    Cool! Looks very similar to the ODW1200 I have.
    It may be tempting to go JL Audio product from battery terminal to sub, hmmmm...
    Jan 2006
    Talking 12" Shallow Mount Subwoofer
    This is what I'm using.
    Size 12"
    Woofer Cone Material Composite IMPP using Interlaced Carbon Fiber and Ultra Long Glass Fiber
    Woofer Cone Design Double Cone with Air Suspension Control System
    Surround 3-Layer Fiber Woven Radial Surround with M-shape Cross-section
    Voice Coil 4 Layer, Long Voice Coil
    Voice Coil Wire Copper
    Voice Coil Bobbin Glass Cloth
    Damper (Spider) None (Air Suspension Control System)
    Top Plate T-Pole Yoke
    Projected Pole Yoke with Vented Pole
    Magnet Construction Strontium
    Basket Design Cast Aluminum Basket with Fin-Shaped Design
    Gasket Rubber
    Wire Terminals Spring Compression
    Specifications
    Watts MAX. Music Power 1400 Watts
    Watts Nominal Power Handling 350 Watts
    Frequency Response 18 ~ 1,000Hz
    Sensitivity 88dB
    Ohm Rating 4ohm
    Recommended Enclosure 0.5 ~ 1.0Cubic Feet
    Dimensions 13" x 3-7/8"
    Mounting Depth 3-1/4"
    Accessory Grill UD-G306
    As for the JL one, I have some ideas i would like to play with, only if i had the extra cash to get a pair! =P
  1. A new VX supercharger option?
    By deermagnet in forum VX Modifications...
    Last Post: 08/21/2011, 08:09 PM
  2. Key fob OPTION button?
    By coachreed in forum VX Modifications...
    Last Post: 05/11/2006, 03:32 PM
  3. another re-badging option
    By videoboy in forum VX Modifications...
    Last Post: 08/10/2005, 07:14 AM
  4. Option Codes
    By thebear54 in forum VX Talk...
    Last Post: 02/18/2005, 05:29 AM
  5. possible supercharger option
    By vxgas in forum VX Talk...
    Last Post: 08/21/2004, 02:02 PM
