Results 1 to 15 of 63
Thread: New Muffler Ideas / Specs?
    1999, Ebony, 0797
    Arrow New Muffler Ideas / Specs?
    Okay, it looks like PowerVault AND Morgan-Tec are out of the VX picture. It's sad, but we must move forward.
    I'm considering 'moving forward' to a FlowMaster Extreme Off-Road Muffler, in the black diamond-plate steel. Perfect for an Ebony VX, no?
    HOWEVER:
    I know nothing about the technical aspects of mufflers. I know what the VX came with, stock...but how does that affect what we can or should do after-market? I mean, I can just buy a single 2.25" in / single 2.25 out model. But is there a benefit or drawback, HP-wise, to going with a larger single in, or a larger single out, or even a dual-out? Will it ruin the engine? Will it get amazingly better gas mileage? Will it do anything at all?
    Also: does it matter if I get the single outlet centered or offset?
    Thanks all!
    The inlet size wil have no effect on the hp, or noise unlesss you increase the tubing in frnt of the muffler. The outlet is a different story. That will effect the sound level, hp, and tq. You can go to big and you will lose low end tq. But you an not really hurt the engine. You need an offset inlet to line up with the stock pipe. If you use a centered it will hit the frame and or the drive shaft.
    Drive it like ya stole it!!!
    2002 Axiom XS
    -20" Eco 820s with Goodyears
    Arrow
    I've been using a Borla Turbo #40658 with a 3" Dynatech Vortex insert cone in the exhaust tip & like that combination.
    It's fairly quiet at idle & not raspy/ ricey sounding under hard acceleration, but still fairly loud.(I was able to pass the MN state db test last fall while wheeling @ Gilbert, MN OHV park.)
    I found the Borla muffler alone to be too loud for me, so I experimented with a Supertrapp tip for a while, but found that to be too quiet/restrictive & just plain didn't like the way it looked.
    The insert cone is perforated & took a bit of hammer work & more than a bit of foul language, to persuade it to take up residence in the tip...hope I never have to remove it.
    1999, Ebony, 0797
    How about this one?
    http://store.summitracing.com/partde...5&autoview=sku
    Do you think it would be possible to find a matching exhaust tip?
    '99 SC Ebony #1961
    1999, Ebony Black, VX ,1976
    In order to use the stock pipes you must get a in / out on the same side. I used a flowmaster 40 series it was the only one I could find the right combination in. shawn
    1COOLVX
  1. Anyone know OEM Speaker Specs?
    By disasterlady in forum VX Modifications...
    Last Post: 12/10/2012, 02:32 PM
  2. Radiator Specs
    By twostep1n2 in forum VX Modifications...
    Last Post: 10/14/2011, 07:46 PM
  3. Wheel Torque Specs
    Last Post: 10/22/2008, 04:53 PM
  4. Factory Wheel specs?
    By TJMaxx in forum VX Talk...
    Last Post: 03/24/2005, 06:11 PM
  5. My aftermarket wheels specs
    By SCUDD in forum VX Talk...
    Last Post: 05/01/2003, 04:16 PM
