What is recommended mileage for timing belt replacment?
Western North Carolina...
Veni, Vidi, Velcro
		IIRC it's about 120K miles, but should be listed in the owner's manual maintenance section.
my owner's manual says normal conditions-100,000 miles,severe conditions-75,000 miles. I replaced mine at 75,000 since i didn't know the history and I was driving out to Moab.
Chi Dog...Dog is my Co-pilot
Onward thru the fog
I'd say if you not the original owner - replace it at 75000. And do not forget to replace tensioner, two pulleys and water pump at the same time.Originally Posted by dkmiller68
1987 AMC Eagle: stock
What uncle said..Since I'm not the original owner of mine I replaced mine at about 90k. The belt looked good but you never know. And as Uncle said replace all you can while your in there..Originally Posted by uncle_asa
I havent done thisyet, but also do thermostat?. I think I remembered that from some old Isuzu info in my head...
The thermostat is located under the common chamber, so no need to replace it at this step since the procedures are not related.Originally Posted by MrCrowley
 Super VXer
						Super VXer
						Is this what what most replace with the "gator" belts?
And can you have Isuzu dealerships aquire those for servicing or are they aftermarket?
