Results 1 to 11 of 11
Thread: Using Oil
    Dec 2003
    Former Owner 0216
    Same deal here. The only thing I haven't changed/cleaned is the EGR, but the VX is running great/normal. Still, I wonder why the oil loss.
    when i got my vx i was going through 1 qt every 1500-2000 miles.. ive since switched it over to quaker state full synthetic torque formula (10w30) and started changing my PCV out with each oil change.. just changed my oil about 2 hours ago and looks like i burned 1/2 qt in 3000 miles
    clean your egr valves - and throttle body - replace pcv valve - see if that doesn't help *some*.
    had my proton erg valve and throttle body cleaned out recently and the mechanic said it was quite the mess in there...
    -biju.
    Aug 2005
    1999, silver, 0887
    Also make sure your oil filler cap gasket is in good condition and on tight. A leak here may keep the PCV open longer than it should. That's where some of the oil goes.
    99 Silver 0210
    Alright, kids.
    New PCV
    New EGR ($189.00!!!)
    Fresh synthetic oil right on the full mark.
    We'll see what happens to the oil and gas consunption.....
    Bim
    Aug 2006
    1999, Astral, Vehicross, 1619
    well after seeing these large numbers, I am nervous. I check my oil every time I fill up. And depending on how hard I drive it uses typically 1 QUART every two weeks.
    I have changed my PCV Valve and that helped considering I was using almost one quart a week. I also changed to synthetic. I should look into my egr next it sounds.
    The only time it smokes is if I stomp on it taking off.
