Results 1 to 11 of 11
Thread: Factory CD Changer Wiring
    2001, FoxFire Red, VehiCross, 1267
    Does anyone know which wires leading from the CD changer to the head unit are the audio outputs? I want to interupt the audio output from the CD changer (thereby audio inputs to the head unit) with a switch and then install a 3.5mm jack for my MP3 player. Knowing the audio output wires will save a lot of trial and error.
    Thanks,
    Jason White
    2001 FoxFire Red VehiCross
    2001 proton yellow #0786
    I just looked through my CD service manual and it showed the radio only, no CD player. just this week i thought of doing this since i pulled out my CD player. so i have I'll be trying to see whats what.
    2001, Dragon Green, 1342
    Jason, I just copied the sound system circuit schematic out of the electrical manual if you want me to email it to you, or I could send the whole manual if you want it, it's about 15 meg, if your server take it?
    Apr 2006
    2007 Suzuki V-Strom 650
    Did you ever get what you needed on this? I'm considering reverse-engineering it with the test station and oscope for a Car PC project, but a diagram would be way easier.
    Oct 2006
    2001 Proton 0586
    Rowhard,
    Is that electrical manual on the CD that Tone provides?
    Henry
    Henry, not sure. But since my last posting on the subject, Scott has uploaded the 1999 Electrical Troubleshooting Manual for all to enjoy along with the 2000 Workshop Manual. Uncle Asa sent it to me and I forwarded on to Scott.
    John
    Quote Originally Posted by Tobert
    Tobert,
    No, I never did get what I needed. The wiring diagram in the manual wasn't much help either. Any chance you've figured it out?
    Thanks,
    Nov 2002
    Arrow
    Why re-engineer the wheel? Just get an interface adapter and plumb your input wherever you like. PIE makes some great adapters and now have a triple input adapter that simply fits in between the radio and changer: Triple Input Auxiliary Adapter
    You'll need to use the Toyota cable as there isn't a specific Isuzu cable: TRIPLE INPUT AUXILIARY INTERFACE TOYOTA
    Jan 2004
    2000 Black Trooper 3248
    I've got this in my Trooper. Works great.
    Nate
    Nate and Joe Black,
    Do either of you use an MP3 player through the auxiliary input adapter. There is a mention in the description that mentions the ouput of some devices is too low and can cause hissing, requiring a line driver to put signal.
    Did either of you have any issue with this?
    Thanks,
    Nov 2002
    Arrow
    Hopefully Nate will pop on and answer as I'm using a Sony single-disc head unit and replaced my factory changer with the storage cubby. Having the ability to read MP3's from disc negates the need for a changer pretty much, but then again I rarely listen to discs due to satellite radio.
  1. Removing factory 6 disc changer
    By phx99blackvx in forum VX Talk...
    Last Post: 07/30/2013, 07:17 AM
  2. Right side O2 Sensor wiring/TOD wiring harness proper locations
    Last Post: 07/27/2013, 11:32 AM
  3. VW Transparent Factory
    Last Post: 06/22/2009, 07:23 PM
  4. How do I disassemble a factory fob?
    By vt_maverick in forum VX Troubleshooting...
    Last Post: 03/27/2009, 11:32 PM
  5. '00 & '01 factory rim?
    By Ruflyf in forum VX Talk...
    Last Post: 05/30/2006, 07:05 AM
