Results 1 to 15 of 86
Thread: question to those with Alpine SC
ScottinMA question to those with Alpine... 02/13/2007, 10:07 AM
Ruflyf just at idle or always? The... 02/13/2007, 12:00 PM
ScottinMA Happens at idle but also when... 02/13/2007, 02:30 PM
Hotsauce I had the early noisy... 02/13/2007, 04:55 PM
Jay Dunford Have you checked the ERG nut.... 02/14/2007, 06:07 AM
ScottinMA Jay, Absolutely, that was... 02/16/2007, 05:56 AM
Green Dragon Green Dragon First VX... 03/28/2007, 10:34 PM
Triathlete Bob, glad to see you still... 03/28/2007, 10:46 PM
WormGod Hey hey, look, it's Dragon... 03/29/2007, 07:40 AM
Ldub I used some Flitz metal... 04/02/2007, 06:15 AM
ScottinMA Bob...what was the length of... 04/02/2007, 12:06 PM
WormGod I just realised last night... 04/20/2007, 11:02 AM
WormGod I found a fairly safe place... 04/20/2007, 11:56 PM
johnnyapollo I'm glad your going through... 04/21/2007, 06:03 AM
WormGod No, I had some email swaps... 04/21/2007, 09:17 PM
johnnyapollo I bought an extra thermostat... 04/21/2007, 09:39 PM
johnnyapollo I've tried several different... 12/01/2009, 04:43 PM
ScottinMA I'll take that advice. ... 12/01/2009, 05:26 PM
PK Scott, if you are currently... 12/01/2009, 09:30 PM
ScottinMA Well that explains it. Today... 12/02/2009, 02:55 AM
    Mine is making a quite a lot of noise these days. Probably a bearing. I have an email in to Tone but wondered if anyone else has delt with this issue.
    Scott
    May 2004
    99 Astral Silver w/ SC
    just at idle or always? The older versions do make a rough sounding noise at idle.
    ----Trans Siberian Orchestra
    Happens at idle but also when accelerating or going up hills. I thought it was an exhaust leak but my mechanic believes it is a bearing in the SC. Does anyone know the warrantee that Alpine gives with these SCs? I'm sure it's been too long for me but tearing down the nose sounds like an expensive process.
    2001 Proton VX 0790
    I had the early noisy bearing. Never any problems other than it sounded like you owned a POS.
    I purchased the newer quiet nose from Alpine and swapped it in about an hour. I remember it being about $400, but not sure. They didn't keep it in stock, and I waited about 8 weeks to get it.
    John C.
    '99 Ironman, 0992
    Have you checked the ERG nut. The aluminum block that comes with the kit is notorious for backing the nut off and letting exhaust gas flow by making noise. I ended up putting locktite on it and that lasted 2 years without a problem.
    May 2004
    I was going to change to the new nose cone a lil while back and it seemed like a $200+ item, cant remember for sure. The nut could very well be the noise you hear, sounds alot like a exhaust leak under acceleration.
    Also have you changed the s/c oil, how did it look?
    Quote Originally Posted by Jay Dunford
    Jay,
    Absolutely, that was the first thing I thought when I heard the noise but that nut was on good and tight.
    2000 Dragon Green VX 0485
    Green Dragon First VX supercharged.
    As The owner of the first VX ever supercharged( Factory installed), I can tell you of the many issues resulting in noise & eventual failure of nose cones rear bearings etc.
    On 5/5/05 I decided I had done all I could do in trying to make a silk purse out of a sows ear & sent the SC out for overhaul to
    www.superchargerTech.com
    Supercharger Technologies
    26988 SE Hwy 19
    unit 47 Old Town Fl. 32680
    352 542 0147
    SC came with a 2 year warranty at a total cost of $490 ( exchange)
    Result was awesome everthing replaced, nose cone, bearings etc every bearing including rear housing bearings replaced. SC is after two years still as smooth as butter with no noise or any other issues.
    Bob F
    Bob, glad to see you still bopping around here!
    Hey hey, look, it's Dragon Bob! Good to see ya lurking around. Hope all is well.
    Found I had to order a new throttle body gasket last night. The existing one was so unusable, it was hardly even visible. Something got the better of it. So, a new one on order from isuzuparts.com (they love me now.... I think I keep them in business). In the meantime, while I wait for it, I guess I will just clean and polish up everything from the throttle body to the EGR. The EGR isnt in the best of shape either, but, if it aint broke, dont fix it. I think my VX is clearly allergic to winter salts here.
    Slow progress is still progress. About 2 hours a night in the garage. I dont recall my previous S/C installs having so much damned hosing, heh. Of course, those were not fuel injected vehicles though.
    Question about polishing: The fuel rails and the EGR mount.... those who polished these, any advice?
    Arrow
    Quote Originally Posted by WormGod
    I used some Flitz metal polish, a cotton rag, & lots of elbow grease...a buffing wheel on a bench grinder would have eliminated the elbow grease thing.
    Also, plug all orfices in the fuel rails with scraps of rag to prevent any metal polish residue from entering the rail.
    Another tip to make your install easier...cut some "U" shaped shims out of sheet aluminium (available @ most hardware/hobby stores) about an inch square, with a 1/4" slot in the middle to aid in alignment of the fuel rails.
    On mine, the rails were slightly mis-aligned when tightened onto the existing (on the Alpine manifold) mounts causing some binding issues with the injectors. When the rails are tightened to the mounting lugs, you should still be able to rotate the injectors back & forth with moderate hand pressure.
    Use emery cloth to slightly enlarge the beveled edge where the injectors go into the fuel rail & ample silicone grease on the upper & lower injector O-rings to keep from tearing O rings, as clearances are VERY tight.
    Good Luck !
    I actually had no issues installing the injectors into the rails. Very mild lubing of the plenum ports and very minor lubing of the fuel rail ports. Then some slow but constant twisting of the injectors as you apply pressure to put them in the plenum. Getting them in the fuel rails was alittle trickier but not so bad really. I laid the rail over the injectors and lined up the ports to them. Applying a little pressure to the rail while slowly twisting the injectors a little at a time and they worked their way into the rail. The rail mounted up right to the plenum with a perfect fit.
    I assumed I was gonna have trouble getting them in since i played hell getting them out of the OEM fuel rail, but I was pleasantly surprised that it was the opposite. In all, the o-rings were still in great shape (only a couple years old) so I didnt have to use any of my new ones. Good to have regardless.
    My only issue this weekend was getting the nut off of the crank pulley. I hunted all over for a crank holder. No shops nor any of my tech friends had access to one (found one that fit various Fords, but no luck on my pulley). So, I ended up using the serpentine belt. I did the old wrap and fold of the belt around the pully and cranked the nut in the opposite direction. Worked like a charm (with some shop gloves that is.... hard on the hands). It's a risky tactic if you want to re-use your belt, so I suggest only doing this if you are replacing it. In my case, I was replacing all belts and gaskets so I had nothing to lose.
    Looking over some stuff at quitting time last night, I was checking out the wiring. Does anyone recall what harnesses, if any, they had to splice and lengthen? Looks like there is gonna have to be some extension for the wiring to reach the new throttle body location.
    Quote Originally Posted by Green Dragon
    26988 SE Hwy 19
    352 542 0147
    Bob F
    Bob...what was the length of the turn around for the overhaul?
    I just realised last night that my fuel hose from the passenger side fuel rail banjo was resting against the EGR piping (below the EGR and mounting block). Granted, I havent had the VX out since the install except to drive around the block and run in the driveway for some tweaking, so no damage done.
    My question.... this pipe generates some healthy heat, so is it safe to say I should re-route the hose further away from the EGR piping? I am not so sure how hot the EGR pipe gets and if it is going to be damaging to the hose. I don;t know why I didnt think of this when installing.
    Afterall, fuel and heat.... really good friends when trying to create chaos.
    I found a fairly safe place to re-route the hose. Behind the EGR is a bracket for some other lines. It took removal of the fuel rail but I was able to undo the banjo and push the fuel line back behind the S/C again and run it back through BEHIND that line bracket and reconnect again. It's pretty much flush with the firewall now and out of EGR harm. Hopefully, this is the last minor issue I come across. She is going out for a good run tomorrow. It's the moment of truth, heh.
  1. Alpine S/C install PDF
    Last Post: 04/06/2010, 01:12 AM
  2. Alpine Supercharger Manual Available
    By BeeVenom in forum VX Modifications...
    Last Post: 07/19/2009, 10:34 AM
  3. Alpine S/C users read this!!!!
    By bigpoppax2 in forum VX Modifications...
    Last Post: 07/15/2008, 11:16 AM
  4. 411 on Tone & Alpine
    By xdfarrx in forum VX Talk...
    Last Post: 03/06/2005, 05:12 PM
  5. Alpine - John Conchie
    By UtahVXer in forum VX Talk...
    Last Post: 09/03/2004, 05:50 AM
