Results 1 to 5 of 5
Thread: Step Bars assembly
    Oct 2006
    2001 Ironman
    Arrow Step Bars assembly
    I picked up a pair of Tone's step bars and will be putting them on in the next couple of days.
    Just looking for any helpful tips that anyone has to share before I get under there.
    Much appreciated,
    Cy
    '99 Blk 0089
    Pretty straight forward but if you want them useful, will need to add spacers to get them further out from the body to be ablr to step on. You can use a bunch of 1/2" OD washers and use longer bolts.
    Oct 2006
    2001 Ironman
    Well, they're on!
    (check pics in gallery)
    How did you get the bolt out to replace it with a longer one?
    Oct 2006
    2001 Ironman
    Bump
    Quote Originally Posted by cyronman
    I'll ask again...
    Step tube mounting
    I am in the midst of installing a set myself. It only takes an hour to do the whole thing (I've had mine on and back off 3 times already). The problem I'm having is that I have 33x12.50 tires and they rub when in a sharp turn. I started with just trimming the brackets and lengthening all of the adjustment slots but it's not enough. When I get the time to be more creative, I'll post the end results but it will probably require custom brackets.
    The only tip I would give is that you'll have to lift the carpet (both front and rear because the body mount bolts will spin when you remove the nuts for the installation). Remember that the large bolt on the front and rear of the tube that connect it to the brackets has a slot for adjustment. You will probably have to loosen them to adjust the spacing of the brackets so that they line up with the body mounts.
    Hope this helps. Good luck.
  1. how do i post pics for a step by step??
    By IndianaVX in forum VX Talk...
    Last Post: 10/03/2006, 10:43 PM
  2. Step bars and off roading
    By WyldWeasel in forum VX Talk...
    Last Post: 04/25/2006, 12:19 PM
  3. Nerf Step Bars?
    By ziralove in forum VX Talk...
    Last Post: 02/09/2005, 02:34 PM
  4. Nerf bars/step bars
    By Charlie in forum VX Talk...
    Last Post: 02/13/2004, 09:35 PM
  5. Tensioner assembly
    By Randy in forum VX Talk...
    Last Post: 01/12/2004, 08:49 AM
