Results 1 to 5 of 5
Thread: TOD throwing code 13
    Jun 2005
    1997, silver
    OK, so we finally managed to read the check light on the TOD by using a piece of wire. It's showing code 13 but where do we go from here? Thanks for all your help so far.
    Mar 2006
    Quote Originally Posted by Nick
    So, that means that "The reference is short-circuited to GND". Here are guidelines from the manual (note, that it is US version of TOD, but I think they are mostly the same, though the pins could be different):
    1987 AMC Eagle: stock
    Jun 2005
    1997, silver
    That's great thanks. Just one more thing - where is the TOD Control Unit situated?
    `99 Astral Silver #1327
    I believe it is under the passenger seat, plug goes through the floor into the TOD.
    Mar 2006
    On US version it is under the passenger seat, on JDM it could be under the driver's. But I'd start checking from underbody harness, most likely you have problem there due to water or dirt on the TOD sensors connectors.
    And one more thing you might need:
    How to Clear The Trouble Code
    The trouble codes saved to the control unit can be deleted by the following procedure if the starter switch is being in the OFF position.
    1. Block wheels.
    Shift the transfer lever to the neutral position between HIGH and 4L, and short-circuit the self-diagnostic connector.
    NOTE: The neutral position between HIGH and 4L refers to the point that turns off the TOD indicator lamps. (However, be sure to check the position before short-circuiting the self-diagnostic connector.)
    2.Turn on the starter switch while maintaining the state of step 1, and step on the brake pedal five times within five seconds from the first step on. (Note that �five times� includes the first step on). (The TOD indicator lamps display the 4L mode whenever the brake pedal is stepped on.)
    3. If the conditions shown in steps 1 and 2 are met, clear the trouble codes saved to the control unit. (After the codes are completely deleted, the code 12 indicates the normal condition)
  1. Rough Idle and throwing p0402 code
    By VehiX in forum VX Troubleshooting...
    Last Post: 05/10/2011, 01:25 PM
  2. Abs Code 35
    By johnny010 in forum VX Troubleshooting...
    Last Post: 01/08/2009, 10:11 AM
  3. just throwing it out there
    By pbkid in forum VX Talk...
    Last Post: 02/16/2007, 06:01 AM
  4. PO 440 - Code
    Last Post: 01/03/2006, 08:21 PM
  5. Cel Code 405?????
    By Mr. I-MAN in forum VX Modifications...
    Last Post: 09/10/2004, 08:13 AM
