yes indeed.. engines up front..
i picked up a haynes manual, read the section on bleeding the hydraulic system, doesnt make it sound difficult at all, makes no reference to even removing anything, so hopefully everythings easy to get to once the cars in the air (im just glad shes parked in a flat lot) i went out there last night to scope it out.. the resivoir for the master cylinder was empty, i put some dot III brake fluid (thats what the cap on it said), had her pump the clutch a little, got some air bubbles then a very nasty looking greenish fluid.. then the clutch would come out on its own but still couldnt get into gear.. guess tonight ill go out there and actually bleed the system and hope that works
