Results 1 to 10 of 10
Thread: ?? Clouded Headlights ??
    EX-1999, Ebony, VX, #0562 - You Are MISSED!
    Arrow ?? Clouded Headlights ??
    I've researched some threads and can't find anything on this.....
    SOOO
    My headlights look like they are clouded/scratched on the inside and after the lights have been on a while, they are extremely hot, so I'm figuring it might be due to that?? I can't figure out what else is causing them to look like that...anyone have an idea what caused it? How it can be prevented in the future? AND....how to get rid of the cloudiness?
    *VX CHIC*
    2001 Foxfire 1232
    Cloudiness on the inside usually means water has been getting in somewhere, unfortunately in that case, not a lot that you can do besides replacement.
    Don't know why your headlights would be extremely hot. I mean the ones on your VX (sorry), or whether there is a connection to cloudiness.
    Did you replace the original bulbs with some aftermarket higher wattage ones?
    99 Silver 0210
    Couple of things:
    If the cloudiness is condensation (water), park in the sun on a warm, dry day and take both the headlight bulb and the horn bulb out. The low colorado humidity will evaporate anything on the inside of your headlight. I just did this because I washed the inside of my headlights out with distilled water (long story) and they were foggy afterwards. Worked great.
    The other issue is, when you replaced your horn lights, did you use 194 biulbs or 168's? The 168's are too large and hot and will burn contact holes in the upper headlight allowing it to fog the area (this is the reason I replaced my headlights in the first place.
    Just my 2 cents.
    Edit: One more (obvious) thing....look closely to make sure it's on the inside and not exterior weathering. Sometimes you have to look closely.
    2000 IronMan #11
    IndianaVX wrote a great how-to, clean up your headlights.
    http://www.vehicross.info/modules.ph...warticle&id=26
    or on the right colum on the page in the how to's
    Aug 2003
    1999,Silver,Vehicross,0928
    after u get the water out, try to seal any holes so it wont happen again.
    Oct 2006
    2001 Proton 0586
    I just replaced my dim stock horn lights with some 11 watt Malibu bulbs from Home Depot.
    Should I be worried about excessive heat in the horn?
    Henry
  1. LED headlights went out
    By simonsayz1 in forum VX Talk...
    Last Post: 09/21/2016, 09:38 PM
  2. LED headlights
    Last Post: 08/25/2014, 07:01 PM
  3. when do you use your headlights?
    By etlsport in forum Polls
    Last Post: 08/19/2009, 11:35 AM
  4. Headlights?
    By Thmstec in forum VX Talk...
    Last Post: 03/10/2008, 06:46 AM
  5. Problem with HID headlights
    By UtahVXer in forum VX Troubleshooting...
    Last Post: 08/17/2005, 03:24 PM
