Originally Posted by
Nick
I really need some help. My TOD check light is constantly flashing and I have a horrible acid taste in my mouth every time I drive it. I have taken it to several local garages who advertise diagonistic reading but none of them can get anything out of it. The three Isuzu dealers I have within a 50 mile radius of my home do not even know what a Vehicross is. Any suggestions?
First, you need to read error codes.
Indication Method of Trouble Code
- Short-circuit terminal 8 of the self-diagnostic connector to GND to display the trouble code on the CHECK lamp.
- If no trouble codes exist, code �12� is displayed continuously.
- If trouble codes exist, code �12� is displayed three times, and the trouble codes, starting from the smaller code number, are displayed three times respectively.
Each digit is displayed with the corresponding 0.4 sec flash and pause and with the pause 1.2 sec after ten multiplier and with 3.2 sec pause between numbers. I.e. 32 will be three 0.4 sec flashes with the 1.2 sec pause and two 0.4 sec. with the 3.2 sec pause before next number.
Once you did that please post error codes so I will post you next steps from the manual.
1987 AMC Eagle: stock
