I picked this up from Costco today for $89, they have them at Wal*Market also for $100. It's a wireless rear camera that gets wired into your brake lines (for power), and the monitor plugs into the cigarette light for power. I plan on changing the cigarette lighter part so I don't lose it as an accessory point. I'll post pics when it's installed.
. The only other limitation I would list right off is that the screen is only 2.5", making it somewhat small, but for just glancing up at to see behind, it should be able to give you an idea of something back there. The screen also shifts display orientations at the push of a button allowing you to mount the monitor at 90 degrees if you had to.
