Results 1 to 15 of 60
    OK, so let me get this straight:
    The hose connecting to the upper end of the PCV Valve is blocked off or plugged, and then the PCV Valve is attached to a vent or "breather"?
    And that's it? Voila? No more oil consumption and no related problems/side effects??
    Sounds simple...
    Quote Originally Posted by VCrossfan
    I can't believe I missed this post, anyway I've had this installed for alittle less than a year now and has worked well. 90 degree pvc fitting with the original hose from the intake still in place with the end plugged and a new pvc valve in my storage trunk just in case I have to reinstall it for some reason away from home..
    BTW these valves cost practicaly nothing!
    So just replace it everytime with your oil change!
    http://www.fram.com/products/accessories.php
    FRAM part number:FV384
    Sep 2004
    1999, Astral Silver, VX, 0938
    Quote Originally Posted by nfpgasmask
    Sounds simple...
    Sorry MASK..A wrong order of letters by me lol. I now have the PCV valve removed and a 90 degree piece of PVC in it's place in the valve cover w/a small air filter attatched to it to allow the engine to vent without any vacuum
    support..
    And this is totally safe for the VX?
    Someone please educate me on what the purpose of the PCV Valve is, and why it can be safely taken out of the picture.
    support..
    Nevermind my last post, this from Wikipedia:
    "PCV system
    The PCV valve is only one part of the PCV system, which is essentially a variable and calibrated air leak, whereby the engine returns its crankcase combustion gases. Instead of the gases being vented to the atmosphere, gases are fed back into the intake manifold, to re-enter the combustion chamber as part of a fresh charge of air and fuel. The PCV system is not a classical "vacuum leak." Remember that all the air collected by the air cleaner (and metered by the mass air flow sensor, on a fuel injected engine) goes through the intake manifold anyway. The PCV system just diverts a small percentage of this air via the breather to the crankcase before allowing it to be drawn back in to the intake tract again. It is an "open system" in that fresh exterior air is continuously used to flush contaminants from the crankcase and into the combustion chamber.
    The system relies on the fact that, while the engine is running, the intake manifold's air pressure is always less than crankcase air pressure. The lower pressure of the intake manifold draws air towards it, pulling air from the breather through the crankcase (where it dilutes and mixes with combustion gases), through the PCV valve, and into the intake manifold.
    The PCV system consists of: 1) The breather tube , and 2) The PCV valve. The breather tube connects the crankcase to a clean source of fresh air, such as the air cleaner body. Usually, clean air from the air cleaner flows in to this tube and in to the engine after passing through a screen, baffle, or other simple system to arrest a flame front, to prevent a potentially explosive atmosphere within the engine crank case from being ignited from a back-fire in to the intake manifold. The baffle, filter, or screen also traps oil mist, and keeps it inside the engine.
    Once inside the engine, the air circulates around the interior of the engine, picking up and clearing away combustion byproduct gases, including a large amount of water vapor, then exits through a simple baffle, screen or mesh to trap oil droplets before being drawn out through the PCV valve, and into the intake manifold."
    So, basically, what we are doing, is sort of bypassing the whole PCV system process? Is that correct? With the hose that leads back into the intake blocked off, does this cause any issues? Or is it ok for the main intake to be used fully?
    My problem is that I am not understanding the point of the PCV system if it should just be vented off instead of fed back into the intake. Is this just a serious design flaw with this particular PCV system on Isuzu's part? Is it basically that the existing PCV configuration is not functioning properly (i.e. not venting or getting clogged)?
    I have been changing my PCV with EVERY single oil change, and my oil consumption has not gotten any better....
    Sorry for all these questions, just trying to learn this stuff so I have a solid understanding....
    Thanks - Bart
    May 2003
    2001 Proton VX
    Egr?
    I also thought Tone or maybe someone else mentioned at some point that the EGR is also a possible cause of oil leaking out and then vaporizing on the actual engine case due to the extreme heat...any thoughts on that...?
    -Rob
    1999, Ebony Black, VX ,1976
    Quote Originally Posted by phant0m-je$ter
    -Rob
    It is not listed under exsesive oil consumption in the manual.So I do not think so. But do not know for sure. shawn
    1COOLVX
    "My problem is that I am not understanding the point of the PCV system if it should just be vented off instead of fed back into the intake. Is this just a serious design flaw with this particular PCV system on Isuzu's part? Is it basically that the existing PCV configuration is not functioning properly (i.e. not venting or getting clogged)?
    Thanks - Bart"
    The pcv valve is used so that the gases in the crankcase get recycled (for emmision reasons). And the valve is supposed to close when there is vaccum,so it cannot suck oil from the valve cover. I cannot say that this will stop your oil consumption problem . I know that it stopped mine. I had changed my pcv valve did an oil change and within 1000 miles or so used 2 qts of oil. So it failed that quickly. The problem is more from poor design of the valve cover. I have not seen the underside of the valve cover but would guess that there is no baffle or too small a baffle to prevent the oil from being sucked up when there is a failure of the pcv valve. If I were you I would try it. I have looked at the chart in the vx manual and a pcv valve failure will cause excessive oil consumption. It will not harm your engine to try this. shawn
    Thanked: 7
    Post
    I talked with my isuzu mechanic (a good one) about this problem happening with so many owners. Through the years he has noticed two culprits showing up again and again. The EGR and the PCV both linked to oil consumption. Bob (Green Dragon) has an old post talking about the hazards caused by a faulty EGR.
    I have been lucky that my VX doesnt use a drop of oil between changes. I do discuss with my mechanic what's going on with forum members VX's. He once made the point of saying for owners to be very careful about buying aftermarket PCV's.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Quote Originally Posted by Anita
    Thanks Anita, So I would try the pcv fix first and if that does not work try cleaning or replacing the egr valve. shawn
  1. Trouble again...
  2. TOD trouble
  4. CV trouble!
  5. VX Trouble
