Wow - I thought I was one of few, but it looks like a lot of VX owners are on their way to a blown motor. I never got a chance to post - but in the fall of last year my motor threw a rod in what I believe was also the #1 cylinder and once I heard the rapping\clicking sound - I knew it was all over. I took it to my local dealership and they did indicate that it's happened plenty of times before because of excessive oil consumption. My 2001 Proton VX had right about 78,000 miles on it and was still well within the 120,000 power train warranty. They asked that I provide all of my oil change records illustrating that I have changed the oil in no more than 7500 mile intervals. Upon reviewing all of my records they replaced the motor with a long block under warranty. I now have about 83,000 miles on it and all is well. However I love my VX like no other and would like to hold on to it for a while longer as I am the original owner and have quite an attachment to it. I would be VERY interested in this PCV valve fix if it stops the excessive oil consumption - especially it I am going to just run into the same issue again.
From what others have experienced - has adding the breather and plugging the hose solved the consumption problems? Has it had any negative side effects?
Thanks all,
-Rob
