Results 1 to 15 of 60
    Hey Shawn, thanks. But pardon my ignorance, what the heck is a "breather"???
    And for hose, what are you using? Just the clear plastic stuff (like the stuff from Home Depot that is used with ice cube makers and cold water lines?)
    I have taken a pic from the vx manual and hope that it will help. where the blue circle is you connect the breather.Just get a short piece of hose and a couple clamps. Or you can get one the same size as the hole for the pcv valve and just remove the pcv valve and install the breather in the valve cover. Second step would be to plug the hose circled in purple.Again I used a short piece of hose and I plugged it with a bolt, again using clamps on the hose.Or you can just plug the stock hose with a bolt and use a clamp. If you use a hose on the pcv valve put the breather pointing toward the front . It will be covered by the plastic cover and you will not see it.The pcv valve is in the drivers side valve cover. Hope this helps. As soon as I can I wil post an actual pic. Right now we are getting hit with a pretty big snow storm. hopefully enough to open the snowmobile trails. shawn
    May 2003
    2001 Proton VX
    Another blown motor...
    Wow - I thought I was one of few, but it looks like a lot of VX owners are on their way to a blown motor. I never got a chance to post - but in the fall of last year my motor threw a rod in what I believe was also the #1 cylinder and once I heard the rapping\clicking sound - I knew it was all over. I took it to my local dealership and they did indicate that it's happened plenty of times before because of excessive oil consumption. My 2001 Proton VX had right about 78,000 miles on it and was still well within the 120,000 power train warranty. They asked that I provide all of my oil change records illustrating that I have changed the oil in no more than 7500 mile intervals. Upon reviewing all of my records they replaced the motor with a long block under warranty. I now have about 83,000 miles on it and all is well. However I love my VX like no other and would like to hold on to it for a while longer as I am the original owner and have quite an attachment to it. I would be VERY interested in this PCV valve fix if it stops the excessive oil consumption - especially it I am going to just run into the same issue again.
    From what others have experienced - has adding the breather and plugging the hose solved the consumption problems? Has it had any negative side effects?
    Thanks all,
    -Rob
    Hey Rob, yeah, that is what I am afraid of. My VX runs well and I baby it so hopefully I can avoid this tragedy in the future.
    With the new engine, do you have the oil burning problem?
    Even if I get this oil consumption problem solved, I will still check my oil once a week as I have done since I owned my VX. Nothing is worse than catostrophic engine failure. Trust me, I know from experience.
    Quote Originally Posted by phant0m-je$ter
    Thanks all,
    -Rob
    Sep 2004
    1999, Astral Silver, VX, 0938
    I can't believe I missed this post, anyway I've had this installed for alittle less than a year now and has worked well. 90 degree pvc fitting with the original hose from the intake still in place with the end plugged and a new pvc valve in my storage trunk just in case I have to reinstall it for some reason away from home..
    OK, so let me get this straight:
    The hose connecting to the upper end of the PCV Valve is blocked off or plugged, and then the PCV Valve is attached to a vent or "breather"?
    And that's it? Voila? No more oil consumption and no related problems/side effects??
    Sounds simple...
    Quote Originally Posted by VCrossfan
    BTW these valves cost practicaly nothing!
    So just replace it everytime with your oil change!
    http://www.fram.com/products/accessories.php
    FRAM part number:FV384
    Sep 2004
    Quote Originally Posted by nfpgasmask
    Sounds simple...
    Sorry MASK..A wrong order of letters by me lol. I now have the PCV valve removed and a 90 degree piece of PVC in it's place in the valve cover w/a small air filter attatched to it to allow the engine to vent without any vacuum
    support..
    And this is totally safe for the VX?
    Someone please educate me on what the purpose of the PCV Valve is, and why it can be safely taken out of the picture.
    support..
  1. Trouble again...
  2. TOD trouble
  4. CV trouble!
  5. VX Trouble
