First of all WHAT OIL SEALS ON THE PISTON ??? Second excessive blow-by is not caused from bad oil rings
Wana bet ? If the oil rings are stuck, your going to get carbon buildup because the oil isnt getting sraped off the cylender walls properly. That causes the rings to stick also = blowby and oil burning. The acids from blowby breaks the oil down very fast and kills viscosity. Thats why your buddys oil turned to what you explained as almost fuel. That lack of viscosity causes metal to metal. Like I said, overdue oil changes and sludged oil are the main cause. Also if you run out of oil, well that isnt suposed to happen. It didnt do that when it was new did it, and were is it going.
