Question I would have about Shawn's mod: if you eliminate the vacuum source at the PCV valve (by plugging the hose), doesn't the valve then stay closed all the time? If you are leaving the valve in place on the valve cover and attaching a breather filter to the valve where the vacuum hose used to be, is crankcase pressure enough to open the valve to allow the oil vapors to vent through the breather?
