Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: OME 912 vs. 913...what's the difference?!?
  1. #16
    2000 IronMan #11
    Both are the same load rate but the 912's are longer.
    Call rock-road if you really want more info. Thats what I did and I do have the 912's installed with 265/75/16 - 32''
  2. #17
    Mar 2006
    Quote Originally Posted by PHO2GR4
    See the 'Pacific Northwest VX Meet: Seattle' thread!
    So, when to expect the comparision pictures? Just pushing ,)
    1987 AMC Eagle: stock
  3. #18
    2001, Dragon Green, 1342
    Eric, lets put a photo shoot together to help solve this. My VX is stock except for the 285 60 18's. Lunch today?
  4. #19
    1999, Ebony, 0797
    Cool
    John! Dammit! I'm at the office all day, doing Photoshop work. How about NEXT weekend? March 10th or 11th? Maybe the weather will cooperate for pictures!
    PS: what were the STOCK tire dimensions for your 18" wheels? My 16 inchers used to wear 245/70/16's, but I don't know what the later 18" wheels came with...
    The 285's must look BEEFY!
  5. #20
    Works for me. Just say when and where since my weekends are always free. Nice and sunny here in Olympia, wait,.... it just turned cloudy again, oh well. You got to love Washington weather
  6. #21
    Sep 2004
    1999, Astral Silver, VX, 0938
    I'll be installing my 913's soon (this week I hope) and I'll post all my #'s. I haven't decided what tire to go with on my new 16"s but for now I'm swapping the BFG 265/70-16's off the stock winter wheels and I might go to the 265/75-16 nitto terra's, then on my aftermarket 18"s which have 255/55 which will look odd with the lift I might install 285/60-18's Height on the nitto's are 265/75-16's are 31.54" and the 285/60-18's are 31.38" so they are close. Pic's and #'s coming soon...
  7. #22
    Eric, the stock were the Dualer HT's @ 245 60 18, 92.875 circumference, 29.56 inch diameter.
    The Toyo AT's are 285 60 18, 98.375 circumference, 31.31 inch diameter.
    yes, beefy, brawny and just so F'in cool looking. Perfect tire for a non raised VX with 18 inch wheel for my taste. You'll see next week I hope.
  8. #23
    1999, Ironman, 1705
    I was just going through some old threads and found this and laughed my head off!! look what iceaxe wrote then see what vehigaz wrote and then look at how many posts iceaxe has... (both quotes are below.)
    can i run the 913's with the stock shocks?
    Quote Originally Posted by iceaxe View Post
    October 2004 and June 2006 ARB application guide North American Version both list the specs as follows.
    Part #, Free Hight, # Coils, lbf/in spring rate, (application)
    OME912, 420 mm, 10.8, 180-300 (medium load Trooper 92-02)
    OME913, 390 mm, 9.3, 180-300 (medium Amigo/Rodeo 5door coil spring 98-02)
    OME919, 430 mm, 10.8, 200-280 (heavy load Trooper 92-02)
    bar diameter is same for each. 913 has lowest coil weight, 912 is + 0.8Kg and 919 is + 0.9Kg.
    I verified the application guide is correct as it pertains to the OME912 and OME913 part numbers with a Rep at ARB-USA who cross checked for any updates.
    I also cross checked in the Oct 2005 International Application guide and the specs are identical number for number, only the applications are listed as follows;
    OME912 (medium load GM Frontera 95-98) and (medium Jackaroo/Monterey 92-2/2001)
    OME913 (medium load GM Frontera 99+ 5 door)
    OME919 (medium Jackaroo/Monterey 3/2001 - 04, Heavy load Jackaroo/Monterey 92-2/2001)
    hope this information is helpful and clears up any confusion about the specs.
    Quote Originally Posted by VehiGAZ View Post
    Welcome, Iceaxe! With clear informative posts like that, you will be a very welcome member of our community!
  9. #24
    Mar 2006
    There should be no problem at all to run with OME-913, there's lot of users who run with OME-912 and stock shocks. I'm currently have OME-913 installed with Tokico shocks designed for Trooper at the rear, but going to replace them back with stock soon.
  10. #25
    1999, Ebony, 0797
    CLOSURE:
    If you've found this thread and read it to the end, look here for a MUCH more accurate and scientific comparison:
    http://vehicross.info/forums/showthr...threadid=15476
  11. #26
    Jan 2010
    '99 Silver
    Just installed 913s yesterday. I have about 50 miles on the some far and they are great so far. I currently have General Grabber AT2 265/70 16 and got 1.75" of lift for the install. To set my torsion bars I went by ride heights before and after, I will be visiting my thealignmentguy tomorrow to reset camber and check corner weights.
  1. front wheel well difference
    By HuzpazA in forum VX Troubleshooting...
    Last Post: 03/10/2016, 05:50 PM
  2. o2 sensors difference between front & rear
    By HCMP in forum VX Talk...
    Last Post: 08/29/2005, 02:12 PM
  3. What a difference new shocks make...
    By Navigator in forum General Tips...
    Last Post: 08/28/2005, 06:48 PM
  4. What a difference!!!!!
    Last Post: 07/18/2005, 06:41 AM
  5. Difference along the Years.....
    By ameetw in forum VX Talk...
    Last Post: 08/26/2003, 10:50 PM
