 Originally Posted by
kelvin
				thanks!
follow-up: will a locked diff in the rear affect my daily driving? ...
Yes. Especially on ice. On ice, an open diff keeps the rear wheel with more traction as a more or less stable anchor, because it doesn't spin. If your axle was locked together, both tires would spin and if you are on a side slope your VX would slide to the low side. Or if one tire got more traction than the other at speed it could cause fishtailing. On dry pavement, a locker causes more aggressive tire wear and sometimes tire chirping around corners. Sometimes the locker will disengage allowing the tires to turn at different speeds but this also causes some disturbing clunking sounds (depending on locker type or brand) and can move the rig around strangely. I would go selectable locker all the way, as I have driven rigs with 3 different types of lockers - ARB, Detroit, lunchbox.
