Pass. side window is getting slow. Not moving around much in the track,yet, so an easy fix may be at hand. This car has had the rt. side window replaced twice, and the driver side done once(under warranty) but no problem since.They are almost always down, and only really get raised for washing so this is no accomplishment. I'm gonna crack the door,and figure out an "ultimate" fix.This is bull$*!#. It is not rocket science to make a damn window go up and down! Shame on Isuzu for making me do this extra, stupid work. I'll try to keep everyone in mind as I work this out, but my inclination is to replace the crappy unit entirely. Some GM unit will fit this bill. maybe replace the epoxy "ears" with metal...I don't know...but this is gonna stop. I'll let you guys know after I get a chance to open the door, and take a look at this mess. Wayne * there's nothing that can't be cured with a grinder, a welder, and a bigger hammer*
this may take you a few times. once done, spray it generously with the silicone spray. this should help.
