Results 1 to 5 of 5
Thread: Brake Juice: DOT3 vs. DOT4
    Hey all,
    I am getting my brakes serviced soon, and I was wondering, what is the difference between DOT3 and DOT4 brake fluid?
    Before I drove out to Reno, my mech drained and refilled my brake fluid. He put in DOT4 instead of DOT3 (which is what comes stock with the VX I think).
    So, is there a difference? Preference? Anything I should know?
    Thanks,
    1999, Ebony Black, 1856
    Thanks for the link. From reading that, it sounds like the only difference is between the boiling points.
    And from what I gather, either DOT3 or DOT4 is fine in the VX???
    Aug 2003
    1999,Silver,Vehicross,0928
    u cant go wrong wiht a higher boiling point......
    Everything except DOT 5 will absorb water and corrode cylinder walls after a few years. I change fluid every year in wet Oregon. I use DOT4.
    DOT 5 will not take up water and holds the water getting by the seal, at the edge of the fluid. This spot corrodes more quickly. DOT 5 has other problems with gas absorbtion and gives a spongy feel when brakes are worked a lot. Members of our group have had bad racing experience with loss of braking when they needed it most. DOT 5 will not eat paint. Show cars and Harley's use DOT 5.
    Roy
  1. I brake for ABS
    Last Post: 03/19/2013, 12:06 PM
  3. Brake
    By Mark B in forum VX Talk...
    Last Post: 06/02/2008, 06:08 AM
  4. using the e-brake
    By etlsport in forum Polls
    Last Post: 11/13/2007, 09:10 AM
  5. The Juice Box
    Last Post: 08/02/2007, 05:35 AM
