Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: VX Fuel
    Dec 2006
    99, Silver, 1972
    thanks for the tips. ill do some research on how to do all those and see if i can get t done myself.
    Quote Originally Posted by IndianaVX
    hey gar,
    since you have just gotten your vx, (welcome to the family) you probably should make it your own by doing some maintanance. off the top of my head, new pcv valve, clean the egr, and the "tube" (do a search) and clean the trottle body, clean iac. these are things i do, and others i think, when im getting bad gas mileage. there may be some things ive left out, but do a search on poor gas mileage, youll catch on.
    congrads, and welcome
    david
    2001 Foxfire 1232
    Quote Originally Posted by uncle_asa
    And it is important that fuel should be unleaded. Otherwise you kill your catalytic converter quickly.
    Maybe you can still get leaded gas in RU, but gas stations here stopped selling it at least 15-20 years ago. New cars don't even carry the "unleaded gas only" labels anymore--you can't get any other kind in the US, at least not intended for highway use.
    Apr 2006
    2000 dragon green 0496
    I run 87 most of the time. Once in a while I put in 93. I don't know if 93 makes the VX run any better. Guess that I think that if I use higher octane and it costs more, it will run better.
    Feb 2004
    1999, Silver, #1349, "SOLD"
    You are in California whichs uses alcohol as an additive to keep the air clean. What they don't tell you is that alcohol is less efficient than gasoline. Therefore the air is cleaner but you have to burn more to get that result. Kind of stupid?
    Go up to Oregon and fill up, you will notice the difference!
    The odometer is calibrated to read with the original diameter tires. If you have change that diameter, your mpg will change also. Bigger tire= lower odometer reading=lower mpg.
    Don
  1. Help: How to Replace fuel lines going to the fuel rails.
  2. which fuel?????
    By jacobus in forum VX Talk...
    Last Post: 09/20/2005, 10:53 AM
  3. Fuel lid
    By jstein in forum VX Talk...
    Last Post: 11/25/2004, 07:47 AM
  4. Fuel Injectors and Fuel Pump
  5. Dyno run & Adj fuel
    By Cyrk in forum VX Talk...
    Last Post: 06/14/2004, 11:33 AM
