Results 1 to 15 of 22
Thread: VX Fuel
    Dec 2006
    99, Silver, 1972
    VX Fuel
    What octane gas are most of you using in your VX. I've gotten 15mpg on my last tank with power mode on. This was my first tank since I bought the VX. I was hoping to get close to 18 mpgs.
    Mar 2006
    Quote Originally Posted by garfull
    I use AI-92 (87 in US) and AI-95 (89 in US) and does not feel any difference in mileage. The selection depends on how much I trust to the gas station (because of poor quality of fuel in Russia, especially in province).
    Check you tires inflation and air filter, this is very cheap, but may significantly affect fuel economy.
    1987 AMC Eagle: stock
    2001,FOX FIRE RED MICA,0251
    I Use 93 Octane With Power Mode On All The Time And I Get The Best Mileage This Way.and The Vx Performs Much Better.
    I run 91 and get from my driveway to the sidewalk on a full tank.
    Dec 2006
    2001, White, Ironman
    I use 87 and 89 and 91...just depends on the cost. I get 15 but I really would like to get better. I have changed my driving habits so that I ride my motorcycle more to make up for the gas prices.
    Mid-grade
    I've been filling up with MID-GRADE lately. I'm not sure what octane that is. I think the VX runs better with cleaner fuel, but it might just be my imagination...
    Dec 2006
    99, Silver, 1972
    i guess ill just have to experiment with the different grades and just see what my vx likes best vs what my wallet can handle.
    Jun 2006
    2001 Proton 0815
    Octane don't matter
    The octane rating of fuel has no effect on gas milage. Octane is is a measure of the fuels anti-nock ability. I think the owners manual states the VX needs 87 octane fuel so that's what you should put in it unless of course it's supercharged then you need to run a premium grade. Running a higher octane grade of fuel is just waisting money. Fuel brands do differ and using known brands is probably best as they put the best additives in. Chevron's Techron is the best fuel injector additive around. Keeps em nice and clean. Stay away from unknown sources, such as Kum and Go, 7-11 etc. These guys often by the bottom of the barrel and you don't know what your getting.
    Driving habits make a difference in milage but the VX aint no gas sipper so it can only get worse. I disagree with the guys that say the power button gets better milage, cause mine don't. My scangage reports milage everytime I fill up and it's accurate. With powerdrive off I get 19.5 -20.0 normal driving (not much stop and go) and just about 18 with it on. I prefer the powerdrive so thats what I drive in 99.9% of the time.
    Seismo
    2000 IronMan #11
    Well stated zilik....... I was about to post the same thing.
    Mar 2006
    And it is important that fuel should be unleaded. Otherwise you kill your catalytic converter quickly.
    1999. Unique Ironman
    well im using 89 its the best for my VX cuz i tryed put 87 and i got bad milege and less power, with premium one i got same as i use 89 so im usung 89 def.
    Just mine 2 cents
    Oct 2006
    2001 Proton 0586
    I just completed a 330 mile trip this week that had me traveling half of the trip with 500 lbs of excess weight. When I refueled I got 19.27mpg using 92 octane.
    Mar 2006
    2001 FOXFIRE 0579
    hey gar,
    since you have just gotten your vx, (welcome to the family) you probably should make it your own by doing some maintanance. off the top of my head, new pcv valve, clean the egr, and the "tube" (do a search) and clean the trottle body, clean iac. these are things i do, and others i think, when im getting bad gas mileage. there may be some things ive left out, but do a search on poor gas mileage, youll catch on.
    congrads, and welcome
    david
    2001 Foxfire 1232
    Quote Originally Posted by uncle_asa
    Maybe you can still get leaded gas in RU, but gas stations here stopped selling it at least 15-20 years ago. New cars don't even carry the "unleaded gas only" labels anymore--you can't get any other kind in the US, at least not intended for highway use.
    Apr 2006
    2000 dragon green 0496
    I run 87 most of the time. Once in a while I put in 93. I don't know if 93 makes the VX run any better. Guess that I think that if I use higher octane and it costs more, it will run better.
  1. Help: How to Replace fuel lines going to the fuel rails.
    Last Post: 08/10/2012, 12:10 PM
  2. which fuel?????
    By jacobus in forum VX Talk...
    Last Post: 09/20/2005, 11:53 AM
  3. Fuel lid
    By jstein in forum VX Talk...
    Last Post: 11/25/2004, 08:47 AM
  4. Fuel Injectors and Fuel Pump
    Last Post: 08/31/2004, 12:47 PM
  5. Dyno run & Adj fuel
    By Cyrk in forum VX Talk...
    Last Post: 06/14/2004, 12:33 PM
