Results 1 to 3 of 3
Thread: suspension question
    Dec 2006
    99, Silver, 1972
    suspension question
    i just got a vx. it has about 94000 miles on it. just had a major tune up performed. ive never driven a new or low mileage one.
    but is the suspension susposed to be stiff in the rear. the front is a soft as expected but the rear is very stiff.
    Welcome to the forum! Suspension supposed to be stiff? Yes... Punishing? No.
    Options/Problems:
    1) Check to see if shocks need to be replaced.
    2) Remove rear bump stops to see if the ride improves - if it does and you like the ride then consider cutting the bump stops in half and reinstall them.
    3) Springs may have lost some strength and may need to be replaced. If your bumpstops are touching the axle, the springs have probably sagged. The bumpstops should be fairly close to the axle, if they are not you might have a set of lift springs or spacers.
    2001,FOX FIRE RED MICA,0251
    i cut the lower section of the bump stops off and wow what a great ride it is now,still stiff but soft at the same time lol i said stiff and soft omg.
  1. Suspension Question (Bose Suspension)
    Last Post: 12/06/2012, 10:32 PM
  2. suspension
    By s2mad in forum United Kingdom Special Topics
    Last Post: 10/26/2010, 02:26 AM
  3. 1999 Range Rover suspension question
    Last Post: 09/03/2007, 02:28 AM
  4. Suspension!
    By diver2k3 in forum VX Troubleshooting...
    Last Post: 02/23/2004, 02:14 PM
  5. VX Suspension
    By grober02 in forum VX Modifications...
    Last Post: 04/11/2003, 11:11 AM
