Results 1 to 4 of 4
Thread: Urgent Help Needed
Threaded View
MIKE TAYLOR Happiness @ Last 12/02/2006, 06:22 AM
rowhard Sorry, I can't help you but I... 12/02/2006, 06:40 AM
Ruflyf Definately sounds like a... 12/02/2006, 08:44 AM
Anita http://www.vehicross.info/foru... 12/02/2006, 10:32 AM
    Dec 2006
    1998,SILVER,VX,1174
    Smile Happiness @ Last
    Hi Vxers.
    I Have A 1998 Vx & I Live In Northern Ireland.
    The Vehicle Is Displaying The Tod Check Light (flashing).
    This Only Happened After Very Heavy Rain. The Engine Completely Dies & Won't Restart Albeit That It Cranks Over. Ther Is No Power At The Fuel Pump Or At The Spark Plugs. After 2 Days In The Garage The Light Went Off & The Engine Started & Went Perfectly. Then Back Into The Heavy Rain & Yea It Quit Again With The Same Light Flashing. Ihave Checked All The Sensors Wires On The Transmission For Corrosion And They Seem To Be Fine & Also On The Front Axle Housing.
    There Does Not Seem To Be Another Vx Here At Home & The Main Dealers Haven't Even Heard Of A Vx. The Owners Manual I Have Is In Japanese Which Doesn't Help Me At All.
    I Would Be Very Grateful For Info On This Light & What It Relates To & Also If Anybody Out There Has Had The Same Problem & Hopefully A Fix For It.
    Yuors In Hope Mike.
    HI V XERS,
    EVENTUALLY GOT ,PROBLEM SOLVED. LONG STORY!
    AFTER TRACING MILES OF WIRE FOR DAYS & CHECKIN EVERY CONNECT, TRACED AFTER MARKET ALARM (TOAD) & FOUND THAT WHAT ACCORDING TO RECIEPT WAS MEANT TO BE A PROFESSIONAL JOB TURN OUT TO BE FITTED BY A BRICK LAYER!!!! RIPPED IT OUT AS IT HAD BURNT FUEL PUMP & PCM RELAYS. CHANGED THEM & BANG OFF THE BEAST WENT AGAIN. SO FINGERS CROSSED & MANY MANY THANKS FOR ALL ADVICE & KNOW HOW REC'D FROM YOU GUYS.
    MERRY XMAS HAPPY V XER
  1. Comprehensive Instructions Needed...URGENT!!
    By xdfarrx in forum VX Troubleshooting...
    Last Post: 08/03/2008, 09:24 PM
  2. Urgent
    Last Post: 12/16/2006, 01:48 PM
  3. Urgent Advise Needed
    Last Post: 09/16/2006, 05:35 PM
  4. Urgent Help needed-Front Diff Drop
    By BritVX in forum VX Talk...
    Last Post: 11/29/2004, 08:26 AM
  5. URGENT! Please help!
    By Leah in forum VX Talk...
    Last Post: 11/22/2003, 05:14 PM
