Well I changed the Idle air control valve and so far that seemed to do it. I also changed the PCV valve and now the check engine light came on. I took it to AutoZone to get the code and it is calling for bad O2 sensor. Apparently there are four and they are 50 a pop. I don’t really want to change them all if only one is bad. Any suggestions?
At least it seems to be running normal.
