Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Engine code P1441 - any thoughts?
  1. #16
    Dec 2004
    Huh - you are probably right. The wording you used really set off some bells from my own experience, but that don't make it so. Even though my VX's problem was from an MAF that was trashed by K&N oil, I had an MAF problem on my 928 that had nothing to do with K&N. Maybe it was just the age of the sensor, but the MAF on that car was freaking out intermittently for a long time before I figured out what it might be and replaced it. The second I started it up with the new MAF, it purred like a kitten.
    So your MAF could still be out of spec on its own - you can always get a new one from AutoZone (stay away from remanufactured ones), pop it in, and return it if it doesn't fix the problem.
  2. #17
    Jun 2007
    2001, Proton
    Vehigaz
    where is the MAF. Searches provided many hits but know location.
  3. #18
    Dec 2003
    Former Owner 0216
    It's the square item located just after the air cleaner box. Very obvious.
  4. #19
    It's the assembly between the orange coupling and the filter (in your case, probably stock airbox) there in the pic below:
    Jun 2007
    2001, Proton
    thanks
    appreciate the help
  6. #21
    Jun 2007
    2001, Proton
    I went to AZ and asked for a MAF
    The picture they showed me looked different than what I am seeing here. Did it run about $100 including a core charg of around $45?
  7. #22
    Looks like this stand-alone....
  8. #23
    Before replacing the MAF you might try cleaning it. A can of MAF cleaner will only set you back less than $5.
  9. #24
    Jul 2007
    1999,Astral Silver,VX,1349
    i removed the honeycomb filter out of mine .......like my vette..less air restriction..
    [SIGPIC][/SIGPIC]...
  1. CHECK ENGINE light - code P0440
    By Yefim in forum VX Troubleshooting...
    Last Post: 03/07/2013, 05:54 PM
  2. Check engine light, no code thrown
    By Marlin in forum VX Troubleshooting...
    Last Post: 01/03/2011, 08:20 AM
  3. Engine Code
    Last Post: 01/13/2010, 11:21 PM
  4. Engine Code P0171-any suggestions?
    By drdavidr4u in forum VX Troubleshooting...
    Last Post: 03/02/2005, 06:31 AM
  5. Replies: 1
