Results 1 to 15 of 24
Thread: Engine code P1441 - any thoughts?
    NC 1999, ironman, 0358
    "Evap system flow during non-purge". Is this the evaporation canister for gasoline fumes? maybe it has a solenoid that is open or closed at the wrong time? Any thoughts y'all? Thanks, Don
    Western North Carolina...
    Veni, Vidi, Velcro
    My 1441 code was due to a capped off vac line when I had Alpine add the S/C. A visit to the dealer for fuel leak problems found the correct placement and no more 1441.
    Roy
    Aug 2005
    2001, Black, 1269
    I had that problem too!
    I had the same issue. I was about to replace all the hoses when I noticed the green wire connecting to the valve (under the rear end plugged into EVAP box) had it's insulation crumbling. The wire was actually broken. Was acutally not working therefor no pressurized tank. stripped and twisted teh wires together, no problem since.
    Damon
    Problem solved...I removed the purge solenoid and tested on the bench...it worked fine. Then I measured the voltage to the solenoid plud...0 with VX off and 12 volts when on...um...reassembled and check engine light still on. Then I disconnected the battery waited awhile (left and returned an hour later), reconnected and check engine light is now off.
    Sep 2003
    2000 Proton Yellow 0600
    Mine started having the same problem today....P1441 code. I'm going to try that and see if it works.
    Three weeks ago I had my EGR replaced. That is what was thought to be my problem from a mechanic I took my VX to.
    Jun 2007
    2001, Proton
    I got the 1441 today
    I used the search engine found several questions asked about it and a ton of different suggestions but no follow up as to what worked to fix it. Can anyone tell me if what caused it has been found? I know it is nit gas cap, I have done recent PVC and the fuel pressure regulator. No mods or anythging
    Dec 2004
    Might your FPR be leaking a teensy-tiny bit?
    Apr 2006
    2000 dragon green 0496
    I recently had same problem
    Did a search for P 1441 code and found many suggestions to correct the problem.
    Checked for vacuum leaks, wired disconnected and tightened the gas cap.
    Went to Auto Zone and they reset the computer.
    Check engine light off for now.
    Jun 2007
    2001, Proton
    My FPR might be leaking
    What is it?
    Dec 2004
    Sorry for the unnecessary abbreviation...
    FPR = fuel pressure regulator. I thought that if your regulator is not seated correctly, you might have a small leak in the fuel system that is caused the code? Maybe?
    Jun 2007
    2001, Proton
    Could be I will check
    but it has been replaced and it was in for awhile before this started happening
    my fuel line leading up to my fuel pressure regulator was cracked when i went to replace the fpr.. maybe that happened to you?
    Jun 2007
    2001, Proton
    well
    I replaced thew PVC valve, put on a new fuel filter and unhooked the battery for a half hour. So far no code. I still sense a disturbance in the force. For some reason I get these occasional slowing as if it was a manual and I downshifted. Not as prominant as that but similar in feeling.
    Dec 2004
    circmand, that sounds like a problem I had once. The check engine light only came on when it "lugged" really bad, though. I ended up replacing my MAF, which got trashed from K&N filter oil. I replaced the MAF and removed my K&N filter, and everything was OK after that.
    I had a similar problem last year after power-washing the engine bay and I got water down under one of the ignition coil packs. I replaced it, but all it really needed was to dry out down where the spark plug goes. The "lugging" sensation was much more pronounced with this problem than with the bum MAF.
    Good luck!
    Jun 2007
    2001, Proton
    VehiGaz
    thanks for the advice but I think my issue is different. I still use the OEM filters have not switched to K&N. Out here in BHC we do not get a lot of rain and I have avoided any water in bay. (haven't washed it)
  1. CHECK ENGINE light - code P0440
    By Yefim in forum VX Troubleshooting...
    Last Post: 03/07/2013, 05:54 PM
  2. Check engine light, no code thrown
    By Marlin in forum VX Troubleshooting...
    Last Post: 01/03/2011, 08:20 AM
  3. Engine Code
    Last Post: 01/13/2010, 11:21 PM
  4. Engine Code P0171-any suggestions?
    By drdavidr4u in forum VX Troubleshooting...
    Last Post: 03/02/2005, 06:31 AM
  5. Replies: 1
