I spoke with Alpine today and we were brainstorming on possibly why I or any of you are running at 4psi with a 5psi pulley.
John asked what kind of filter I had....K&N. Stock or cold air intake?.....stock.
It came down to...."Oh, you should have a separate air intake hole in your air box."......"What?"....."In your SC instructions there is a section that tells you to add another hole to the bottom front part to your air box."
The stock air box can not feed the SC as it should and with this "hole" should add 15-17hp and keep you at full boost.
...."I don't seem to remember seeing that, I'll check."
I pulled out Alpines and checked Tones intructions off of his site(also printed out his as well).....nothing.
I did notice on the cover page of the instructions that there is one(separate induction hole) in the pic of the engine(see your instructions).
Come' on guys!.....what the hell!
