Results 1 to 5 of 5
Thread: Tranny Swap Options anyone?
    Dec 2003
    89 Kawasaki Green Amigo
    Thought you guys might wanna check this out.
    4x4wire Tranny swap thread
    Basically what this means is that you can toss the wimpy 4l30e and isuzu t-case and get a beefy 4 speed with better gearing and pretty much any t-case you want, including the Dana 300 or Atlas II. You'd lose the TOD but you would gain a ton of aftermarket, including 4:1 gears for the D300 or even 5:1 gears in the almost unbreakable Atlas. Not to mention the ability to select front and rear wheel drive separately. Oh and did I mention its all bolt on with no special machining required. You'd have to fab a custom crossmember most likely, and probably rig something for the shifter or install an aftermarket one, but realistically with the right tools and skills this entire swap could be done in a weekend. Sounds pretty freakin cool to me.
    Dallas
    WWW.STINKYFAB.COM
    2001 Proton VX #0662
    I'd be into it if it involved dropping in a manual. Am I the only one that dreams of driving a stick again? I think a VX would feel sooooooo cool if you could shift it yourself. Is this totally unrealistic?
    Canadian VXer!
    Dec 2003
    That could be done too. There are plenty of manual S10s out there. The 60* blocks have a ton of options. You just gotta bust out the parts catalogs. a beefy stick shift should be just as easy.
    Dallas
    Aug 2003
    1999,Silver,Vehicross,0928
    a stick shift vx....oooo
    ________
    Live sex webshows
    99 Silver VX
    You can use the trooper 5 speed manual out of a 98 and new and still retain TOD
    remeber you will need a manual trannied computer too....
    Big Meat VX
  1. S/C oil options
    Last Post: 07/03/2008, 05:21 PM
  2. outline of tranny filter on tranny pan......
    Last Post: 05/16/2006, 08:44 PM
  3. Differential options for the VX?
    By Chef in forum VX Modifications...
    Last Post: 02/07/2006, 11:33 AM
  4. Lift options
    By Rooster in forum VX Talk...
    Last Post: 11/19/2004, 12:55 PM
  5. Help... Switching from mechanical tranny to fluid tranny???
    By ScubaSteve in forum VX Troubleshooting...
    Last Post: 10/03/2003, 03:41 AM
