Results 1 to 15 of 18
Thread: Were is the transmission dip stick?
    Apr 2005
    1999,BLACK,VEHICROSS0429
    Question Were is the transmission dip stick?
    Were is the transmission dip stick? I'm baffled. please help.
    TARHEEL UNC-ROSS
    Feb 2003
    dude, there isn't one!!!
    you must have vx in park and started and undo the tranny fill bolt and pump fluid in there untill fluid comes out, then shift thru the gears and then fill again till fluid comes out..oh yeah, don't drive it first or pressure will put your eye out
    Angry
    SO TRUE...........and man did I drive myself VEHIcrazy looking for one too!!
    This has to be the biggest blunders on the VX design (*besides the window problem).
    John
    May 2003
    2001, Kaiser Silver #1213
    How often to change Trans. Fluid?
    My transmission fluid is visibly black. Is this not something that the dealer typically does? They haven't brouhgt it to my attention the last 3 visits. Or are they waiting for my transmission to fail?
    I think the manual gives 60k or 100k before having to change the fluid under normal conditions. Mine has 45k?!?
    I am getting ready to change my Trans. fluid and filter out at 54K. I'm not waiting for the old ticker to turn 60K
    John
    '99
    This is from the VX repair manual. I've had my tranny serviced twice so far. Frequent fluid changes are always a good idea, regardless of the maintenance schedule.
    2000 Dragon Green VX 0485
    Quote Originally Posted by CSTYLES
    My transmission fluid is visibly black. !?
    I would change the xmission filter & power flush this puppy without delay, right now!
    Quote Originally Posted by SPAZZ
    ...oh yeah, don't drive it first or pressure will put your eye out
    I don't know why, but this quote had me laughing for 10 minutes. Maybe it's the visual.
    What do ya'll think about swapping the pan with a dipstick capable 4L30 pan'd vehicle -like a Blazer or E36 BMW? Why'd Isuzu go with a sealed unit anyways? Is there something special about this particular tranny?
    Aug 2003
    1999,Silver,Vehicross,0928
    Quote Originally Posted by mbeach
    probably to keep dirt or stuff out of the tranny....?? tats wat i always thought
    ________
    Web Shows
    Quote Originally Posted by MZ-N10
    If that were the case, all automatic cars would not have dipsticks.
    Heck, my WRX had a dipstick on a manual transmission -and that car was built for rally.
    I'm sure that there's some bureaucratic reasoning at work here, no engineer worth his calculator would design a transmission that was impossible for the user to check the condition of.
    ...Or maybe it's because of where the tranny came from...
    Isuzu uses the 4L30E type transmission built by GM of France
    I guess they figured "If you have one...you are one"
    John
    I think it is the French trying to stick it to us again....
    LOL...
    Fransmission
    Seriously, do we share a pan configuration with another 4L30E car/truck. I'm all for swapping it out when I do my next service.
    Aug 2003
    2001,White,Rodeo Sport,
    LOL...
    Fransmission
    Check a bmw z3, same tranny in there.
    May 2004
    Used to own #777
    Don't get your hopes up: the dipstick doesn't mount to the pan. The dipstick mounts through a hole in the top of the cast section of transmission that the pan mounts to.
    http://tad.grosvenor.org/gallery/94TrooperMods/CIMG1427
    Looking at that photo you'll see the output for the transmission cooler at the front of the middle section of the transmission. If you look at the 1994 transmission behind it, you'll see an oil black hole there. That's where the dipstick connects to the transmission body. The newer (1999) transmission doesn't even have a non-drilled depression there. So the best that you could do is to remove the transmission, drill the case and hope that it seals. There also might be a difference in the valve body inside the pan there as well, I don't remember that part.
    Be sure to keep the later non-dipstick pan too. The earlier pans didn't have a drain, so changing the fluid was very messy. I ended up sucking the fluid out with a topsider instead of trying to lower a pan full of fluid.
    -Tad
  1. New boom stick
    By RabidPony in forum Chit-Chat ...
    Last Post: 02/26/2014, 08:02 AM
  2. Dip Stick
    By Cuda66 in forum VX Troubleshooting...
    Last Post: 10/19/2013, 10:13 PM
  3. no transmission dip stick/filler tube???
    By vxfocus in forum VX Troubleshooting...
    Last Post: 05/11/2011, 08:57 AM
  4. Whoops....pesky 4wd stick
    Last Post: 02/01/2010, 02:33 PM
  5. Trans dip stick....
    Last Post: 03/11/2004, 02:42 AM
