Results 1 to 15 of 23
Thread: Rubber Headlight Gasket
    2001 Proton 0951
    Has anyone replaced the rubber headlight gasket? Both of mine came off and I can't get them back in. Also, where can I order new ones?
    Thanks for your help!
    Life is what happens when you're driving a VX...
    Feb 2004
    99 White Ironman
    Go to St Charles . They are the best!
    Jan 2004
    1999 Silver VCross 1925
    Actually, just remove the headlights and then get some silicone glue and get them back in there. If you decide to get new ones from St Charles, they are about 15 bucks a piece, not bad. I will still re-enforce the factory adhesive with silicone because it will happen again and again and again. I did it with House clear adhesive (all purpose), applied it to the old gaskets and they haven't come off in over two years.
    Julio
    2001 Proton 0951
    Thanks guys, I will do that!!!!
    Mar 2004
    2000 Firefox Red 0758
    I recommend the purchase of a 3M product to adhere the gasket to the headlamp assy ......
    3M Trim Adhesive .......... 3M Super Trim Adhesive ........ 3M Trim/Emblem Adhesive ...... ??? ....... 3M Super Duper Quick Tack This-and-That Adhesive .......
    I can not remember the exact name of the product(s) ........ visit your local parts store - a parts store that specializes in body shop supplies ....... they will be able to recommend the correct product.
    I would probably begin by applying adhesive to the 'flat' sections of the gasket and then applying the gasket in place (difficult to describe what exactly the 'flat' section is) ....... when the initial adhesive is dry and the gasket will stay in place, I would then probably apply the adhesive to the other parts of the gasket ....... this method may be slightly easier and less 'messy' than applying the adhesive to a large portion of the gasket and then attempting to fool with the sticky stuff as it is going every which way ......... including all over the lens ........
    2001 Proton 0951
    Thanks T2P, I'll give it a try. I've been driving with no gaskets on my headlights so I hope I'm not doing any damage but I'll get the new gaskets asap and put them in.
    Thanks for the advice.
    covered under warranty
    I have 2001 VX w/ 14k miles and mine came off couple of month ago.
    I took my VX to dealer and they replaced both headlight assembly under warranty.
    they told me that's the only way to fix loose rubber gasket.
    Jkim
    01 black VX
    04 black V40 LSE
    May 2003
    clear GE RTV Silicone II........works like a champ available at Lowe's @ about $3 for a small tube. Been on my VX for 2yrs now and still holding strong!
    100% Silicone
    Use indoor or outdoor. Low odor. Watertight seal will not shrink and stays permanently flexible. Withstands the most extreme weather.
    Good for all purpose glueing of medium to large size objects
    Available in small tubes and caulking tubes for power-glueing sessions
    Bonds with most surfaces
    Appears dull when dry and is not paintable
    Available in three colors clear, white and black
    Works well under most environmental conditions
    Tends to be less expensive by volume than other adhesives
    Product Silicone II Household Glue & Seal
    Manufacturer GE Silicones
    Waterford, NY
    1-800-626-2000
    Availability All Hardware Stores
    Pricing 2.8 FL. OZ. Tube ..... $ 3.00
    10.2 FL. OZ. Caulking Tube ..... $ 8.95
    2001, Yellow, Vehicross, 0786
    Cool
    mine doesnt even have the gaskets, they were missing when i got my vx and i never bothered replacing them.
    Does it matter, do they actually do anything?
    Pete
    3M (or other brand) contact weatherstrip adhesive is the CORRECT type of bonding agent to use.
    Nov 2002
    I'll second (or third) the 3M weather strip adhesive. Make sure to get the black rather than the mucous colored goo. I pulled off the grill and bumper cover to do mine. Took about two hours to completely clean off all the old adhesive from the lights and seals before replacing with the 3M material. Still holding strong and looking as good as new!
    May 2004
    2001 Foxfire Red 1306
    Mine Too
    My new VX is in perfect shape, except it's missing one headlight gasket.
    What is this about replacing it under warranty? My truck is still covered.
    2001 vehicross, ebony black, #1301
    Jimbo:
    I just visited my dealer and they are replacing the entire headlight assembly (including gasket). The top of my headlights (by the "horn" light) had UV damage. The dealer didn't give me any hassles. The lights had to be ordered; we'll see if they can keep from screwing something else up on the install!!!!
    Rob
    So is the 3M Weather Strip Adhesive still the choice for winners or has someone come across some new and improved goop? Wanna take care of this (again) before I reassemble the VX.
    May 2003
    Wink
    I haven't had to touch mine again since using the GE Silicone and I posted up above in '04 which was a couple years after using it. so that means I haven't touched the seals in nearly 5 years...I used clear and neatly applied it and I'm hard-pressed to see anything was done compared to stock. I have no regrets whatsoever with the silicone.
    I use 3M products at work and they are great... so do what your heart tells you to do.
  1. Missing headlight rubber alternative....
    Last Post: 09/21/2009, 12:33 PM
  2. rubber gasket around front headlights
    By glock in forum VX Talk...
    Last Post: 07/15/2007, 04:58 PM
  3. Rubber Headlight Gasket
    By Hanalei in forum VX Troubleshooting...
    Last Post: 06/30/2004, 09:46 AM
  4. Headlight Gasket Fix
    By EclipseGSX in forum VX Modifications...
    Last Post: 10/27/2003, 05:28 PM
  5. headlight rubber gaskets...
    By jester0064 in forum VX Troubleshooting...
    Last Post: 09/04/2003, 11:59 PM
