Results 1 to 15 of 27
Thread: 3000RPM Idle & Overheating... fixed!
    Aug 2007
    2001, Proton, Vx, 0000
    Hey everyone... been a while since I visited the forum or did any work to my Vx (other than regular maintenance) but got an issue that became a major problem not too long ago, resolved the issue today and wanted to share my experience as I didn't find anything overwhelmingly decisive in this area on the forum (although there is a thread or two that come close).
    Symptoms:
    Intermittent high idle topping out at 3,000 RPM when in "Park" or "Neutral" - around 1,200RPM when in gear... and bearing down on forward. The idle was consistent but high, required extra effort to stop the vehicle at lights, and keep it from moving - it lounged forward once foot is off gas pedal.
    Subsequently, the vehicle began to run at extremely high temperatures. Never quite overheated but almost right on top of "H" on the gauge. Fuel economy went to *****.
    Resolution:
    Pulled IAC and MAF sensor, cleaned both with CRC MAF Sensor Cleaner and IAC was cleaned with CRC Throttle Body/Intake Cleaner - both readily available at your neighborhood auto store like Autozone, Advance Auto Parts, Pep Boys, NAPA, Carquest, O'Reilly, etc... Both sprays did a good job getting grime and gunk off with seemingly no effort. Also removed and cleaned EGR valve and replaced PCV off the driver's side of the engine head cover. (new PCV was like $2.98USD)
    Hope this helps anyone having similar issues. My Vx is an '01 with 111,000 miles on it at this point. If anyone has any questions, post 'em here!
    Good luck.
    May 2009
    1999 Ebony Black/Red
    thank you!
    Aug 2007
    Update: this issue subsequently came back and the only way I was able to resolve it is by replacing my EGR valve (with a gasket it came with). It's still hiccuping once in a while on me so I may go ahead and replace my IAC... maybe MAF sensor too... I'll post updates whenever I'm able to resolve this completely.
    - Dion
    Feb 2004
    '01 Ebony #0830
    Hi'
    A usual fix for those symptoms is to replace the fuel pressure regulator.
    I've done it on 2 VXs now. Fixed both. Hope yours stays fixed! If not, try that.
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    01, LineX tan/black, 1055
    Quote Originally Posted by SilverBullet75 View Post
    Hi'
    x2 (but only one VX)
    2001, Ebony Black, 1153
    Failing FPR can damage #6 cylinder if not addressed quickly.
    Feb 2012
    2000,grey,0162 99 silver 0942
    I need help with all these abbreviated parts please!! The only one im familiar with is AIC (air idle control) right? I too have been having ruff idle issues which is now stalling at stops please help!! Can anyone shoot me some how to links or even vids on cleaning these parts? yes I'm a wetart but im trying CRC MAF ? where n what is EGR valve?? oh and I do know the WTF one as well LOL
    [SIGPIC][/SIGPIC]the 2nd mouse gets da cheese
    Quote Originally Posted by catskilljay View Post
    Did you ever get your issue(s) resolved?
    Feb 2012
    ok so Googled Youtubed and think im ready to tackle probs tomorrow. wish it wasnt Dec and cold in NY with no garage brrrr
    Mar 2012
    sold
    maf = mass air flow sensor
    pcv = positive crankcase ventilation
    fpr = fuel pressure regulator
    tps = throttle position sensor
    icv = idle control valve
    egr = exhaust gas return valve
    PCV is also sometimes referred to as: Pressure Control Valve.
    Feb 2012
    Great thanks alot guys!! Ask and you shall recieve I dont suppose it would be to much to ask if someone could direct me to some pics or videos of locations of parts to be cleaned/replaced? do's dont's etc. I've watched a ton of vids on youtube but non of VX... in the mean time gunna keep searching this wonderful board and innerweb gathering knowledge till the freezing rain subsides....
    The MAF is the honeycomb thinggy on the side of the airbox (airfilter housing) where the big tube goes in. I don't remember ever seeing a write up on it.
    Here's a How2 on the Fuel Pressure Regulator.
    Mar 2012
    sold
    tom's fpr writeup made it super easy - the idle control calve and throttle position sensor are super easy they are both where your air intake goes into the engine - pcv is just pull out with your fingers its on your drivers side valve cover - just make sure you hook up the vaccuum lines to all of them when you put the new ones on - i clean my pcv with carb cleaner and reuse it
    I can't take credit. I just created the pdf. Sorry but I don't remember who's efforts I shamelessly plagerized from.
  1. Fast idle, low idle, (stalling) temp gauge all over the place.
    Last Post: 11/07/2016, 09:48 PM
  2. Idle probs FIXED!!
    By Grif in forum VX Troubleshooting...
    Last Post: 10/26/2014, 05:30 PM
  3. Overheating problem fixed.
    By Lashsquat in forum VX Troubleshooting...
    Last Post: 09/26/2007, 12:09 PM
  4. Overheating
    By bobmumgaard in forum VX Troubleshooting...
    Last Post: 06/27/2007, 01:51 PM
  5. FINALLY: Rough idle and stalling problem fixed!
    By Yefim in forum VX Troubleshooting...
    Last Post: 08/19/2004, 09:45 PM
