Results 1 to 15 of 21
Thread: How does tod work?
    Feb 2010
    2001 Kaiser VX 0000
    How does tod work?
    I spent 6 hours stuck in some mud on Friday. I have no 4x4 experience at all. I've owned a CRX and 2 GTI's so my understanding of these drivetrains is rudimentary at best.
    Here is why I'm confused...
    The rear driver side wasn't touching any ground and the driver front was, but didn't appear to be spinning. The front passenger side was also spinning freely but the passenger rear wasn't.
    The two wheels with decent traction areas weren't moving and the two that had no traction were spinning freely.
    Why?
    Nov 2007
    '01 Ebony Black VX, 0801; '01 Kaiser Silver VX, 1002
    I'll give this a shot....
    As I understand it, the TOD computer compares front and rear driveshaft speed. If the rear is moving faster than the front, indicating some wheel spin, the progressive clutch pack keeps sending torque to the front driveshaft, until the split is 50-50. VX's have a limited slip differential in the rear, but not in the front, so both rears should turn. Since the front differential is not a limited slip type, as soon as the first front tire starts spinning, the other front tire will no longer try to turn. In trail/muddy conditions, you can select 4L on the transfer case shifter. This locks both front and rear driveshafts together, and eliminates the progressive rear/front torque split. In 4L, it stays at 50-50. Still, if you lose traction on one front wheel, you'll get no help from the whole front end. Both rear wheels should always be pulling.
    If I've missed anything, let me know, folks!
    Randy
    Jul 2004
    2000, Kaiser Silver, 0196
    Quote Originally Posted by DannyDigital View Post
    Why?
    The TOD varies the torque split between front and rear via an electromagnetically activated clutch pack. If you're in 4L this clutch is bypassed and the transfer is handled by a mechanical lock so torque split is 50/50. The reason you got stuck is the open differential in the front and limited slip in the rear. Torque sent to the front will follow the path of least resistance - if one wheel spins, all the torque gets delivered to the spinning wheel with no traction. On the rear, because of the LSD, there is some torque delivered to the non-spinning wheel but obviously not enough to get you out of trouble. Did you try feathering the brakes? Sometimes that will stop the spinning wheels and divert torque to the ones with traction.
    If you're going to do this on a regular basis you might want to invest in an air locker. Don't know if it's better to have a locker on the front or the back though - will leave that bit of advice to the off-roaders on here.
    I hope you weren't by yourself!
    Feb 2010
    2001 Kaiser VX 0000
    Ah that makes sense. I was with my brother, but I'd been through that trail a couple times without problems so I wasn't too worried. It was a little muddier than usual though.
    Had to wait for a friend of mine to get out of work to pull me out... Now I see why someone said they keep a deck of cards in their truck at all times.
    '99
    This is a nice little Isuzu tech video I have about TOD from 1998. I believe everything is the same for our VX except we have no TOD switch. Ours is on all the time. The method shown for reading and erasing TOD codes is the same as in the VX manual. The quality is not the best, but it's very watchable.
    11:39 and 13.9 mb, WMV file only-
    http://www.drivehq.com/file/df.aspx/publish/mgpa/techvids/tod.wmv
    Mark
    If you were only going to lock one end or the other the front would be your best choice since it is an open diff. The rear limited slip can be manipulated with a slight application of the E brake. Of course optimally lockers front and rear is the ideal set up for off road.
    I had an old military instructer that when confronted with a question on how something worked that he had no answer would always answer "AM/FM"...
    "Amazing Miracles and F'n Magic"!
    Aug 2005
    1999, silver, 0887
    Remember, unlike alot of SUV's, with Isuzu's full-time TOD on, the VX is truly rear-wheel drive biased, meaning the torque goes to the back first, where the LSD resides. This tendency is obviated when the 4L is engaged, then it mechanically equals things up, front to back, torque-wise. The automatic full-time TOD system was originally meant to allow smooth transfers of power across varying terrain, at relatively high cornering speeds for a tall vehicle. Superior, changing-terrain, handling was the primary purpose of the full-time VX TOD system. Swamp crawliing calls for the 4L mode, exclusively, and the addition of locked front hubs would help immensely to compensate for the lack of LSD on the front axel.
    Feb 2009
    1999,silver, 1516
    I agree with everything that's been said here. But it looks like you could use some tires with a bit more bite as well, especially if you will be doing a good bit of that sort of riding.
    1997 Silver JDM 0623
    Can't understand why the LSD wasn't turning both rear wheels together ?
    Agree with the comment about being in 4lo and having better tyres
    cheers
    Steve
    Isuzu Vehicross 3.2 V6 24 Valve
    I've never heard that before, could you explain?
    +1 - Perhaps the wisest (and cheapest to take) piece of advice in this entire thread.
    Jul 2004
    Quote Originally Posted by Greasemonkey View Post
    Guess that would be the "S" in LSD. It's limited, but there is some slip...
    2001, Dragon Green, 1342
    AM/FM
    good one Billy, must remember that one
    Was a trick that Todd Adams taught us, or me anyway. As your starting a climb or whatever, you apply some emergency brake like in a hand brake turn and that helps lock up the rear diff. It is a feel thing,.....
    AM/FM
    AM/FM
    Hmmm, poor man's locker? It sounds great, can't wait to try it out on the trails.
  1. will a 3.2 work
    Last Post: 05/09/2012, 11:33 AM
  2. Do these actually work?
    By Paul_A in forum VX Modifications...
    Last Post: 03/05/2012, 12:24 PM
  3. Will it work???
    By djkymar in forum VX Talk...
    Last Post: 09/15/2007, 08:49 AM
  4. Do any of these work?1?
    Last Post: 01/18/2007, 03:11 PM
  5. would this work...
    Last Post: 11/12/2006, 12:54 AM
