Tonight I removed the front sway bar completely from the vehicle. The ride is alot softer and cushy in the front. No more carving corners but hey it's an off-road truck. I left the rear sway bar on and hooked up and my logic is that if it's limited then maybe it'd force the front to flex to it's potential. Does that sound like a sane thought on the subject? Is there any harm that could be done by leaving the sway bar off? I can't foresee any problem with it. It always seemed odd to take an IFS setup and limit it to not independently moving like a solid axle by putting a sway bar on. I was able to flex it out and max out both front and back at same time. Will post the pics up later cuz i just don't have the patience for it now. Anyone have any thoughts or comments or anything else please do share. Should i put it back on and keep it that way? Should i stay as it is now? Should i take the back one off too?
