I'm trying to fix my window issues.....I've read a ton of posts here, but could still use some input & advice from you pros! HELP!!:
1) When I got my VX last week I tried "Phinnes" fix where I widened front track & bent the bracket forward, it improved a bit. Then I cleaned out what looked like years of old lubricant junk, some dry and cracked, some beige & thick & greasy. Despite reading a ton of posts here about window fixes, being ignorant, (remember, be kind....) I sprayed WD40 on the front rubber track. Window worked perfectly.
Then learned not to use WD40 as it can dry out. So a few days later, took the door apart as window was slowing down already, removed the front rubber track, cleaned it out (and yes, the WD40 was dry). Interestingly, with the rubber front track COMPLETELY out, the window still showed some significant binding going up....This lead me to reason that the BACK track is involved. Applied pure silicone spray to the entire BACK rubber track, all the way up to top of window frame. Window worked perfectly. This was still with front rubber track REMOVED. BTW, this didn't score or scratch the front glass at all. I then tried to figure out if I had a tilt problem or not and if "spacer fix" would help.
When I first got car, the window did jump out of the track about 6" up, but since lubricating front rubber and bending front track, never jumped out again, so I don't "think" I have a tilt problem??
Now since it was binding when front rubber was completely OUT (and was not rubbing on the metal front track), I'm thinking I have a tilting issue where the glass is pressing too hard on the Back rubber channel, on the outer side of it. Just like "Bulldoggie's" drawing, except mine doesn't jump out of track any more.
When I reassembled it all, it worked perfectly, but I figure I'll have to keep re-lubricating it over time. I'd prefer permanent fix.
~How frequently do you think I'll have to apply silicone spray?
~Should I get SBC's brackets so I can move the window slightly forward??
~Or apply the spacer fix to change the tilt?
~Or try what Gussie2000 just mentioned yesterday, to cut some of the rubber off going down track? (Gussie2000, can you give me more details so I clearly understand what to do? Any future problem with water getting in anywhere?)
2) Also, vapor barrier plastic completely gone. I see fix to get some 4 mil plastic to replace, but is it IMPORTANT to replace the barrier? Is CO2 the risk?
3) Also, not clear on the nylon arm guides (white nylon tabs on the vertical regulator track). Are these what come loose, or have too much play? LittleBeast posted pics and labeled them "loose plastic tabs". Neither my white plastic tabs nor the tabs that actually hold onto the glass are broken...YET. I should get SBC's metal brackets before those current brackets holding glass break. But I don't think SBC's metal brackets involve the white nylon guide tabs at all..... What can be done about them
p.s....I haven't even TOUCHED passenger door yet....that window was worse than driver's side, so by the time I tackle that one, I should have all the answers I need from y'all:grinp:
