Results 1 to 12 of 12
Thread: I installed an in-line thermostat
    '99
    Wrench I installed an in-line thermostat
    edit
    I like it.
    It's in my mental file cabinet now so that if I ever have to replace my thermostat, I'm sure I'll make the conversion.
    BTW, a lot of thermostats come with a small blow out plug. If you get one, you can just pull out the plug & the hole to ensure flow is already there. I did that on the Eclipse because I was told that they have a problem with trapping air behind the thermostat, keeping it from opening.
    The one for the Eclipse left a 1/8 inch hole after removing the blow out plug.
    Would there be any benefit to running the inline thermostat in addition to a functional engine thermostat?
    Thumbs up Rip you a new one ???
    Oh HELL no, that looks like a right smart solution to me.......
    Thinking outside the box is a good thing...
    ESPECIALLY when the box is located under the friggn intake...
    I can't think of what it would be, other than having a fail safe heater/defroster.
    Might even reduce flow slightly...
    Aug 2005
    1999, silver, 0887
    I like this post, it makes me think.
    Quote Originally Posted by blacksambo View Post
    Always the hallmark of a great thread...
    Oct 2012
    2001, Proton, 0586
    I was driving around yesterday while plugged into the scan tool and noticed that my temps were in the 158-159 range! I also think that it is too low! I am thinking of installing a new, 170 deg thermostat. Is that our factory spec?
    Dec 2012
    99 silver 1997
    I know they usually go when open, but what happens if the factory stat ****s the bed closed.
    Oct 2012
    2001, Proton, 0586
    I wonder if someone installed 160 deg thermostat on my VX (since it was from the south)? The temps were too perfectly close to 160 for it to be a fluke.
    Oct 2012
    2001, Proton, 0586
    I understand, but I think I might be up for the challenge .
  1. thermostat temp
    Last Post: 04/06/2014, 01:50 PM
  2. Thermostat
    By Chopper in forum VX Troubleshooting...
    Last Post: 07/04/2010, 09:29 AM
  3. thermostat replacement
    Last Post: 04/24/2010, 05:51 PM
  4. $300 thermostat!!!!!!!!!!
    Last Post: 05/08/2008, 09:26 AM
  5. thermostat question?
    By Sheik-YurBooty in forum VX Talk...
    Last Post: 11/24/2004, 07:27 PM
