Page 1 of 6 1 2 3 4 5 ... LastLast
Results 1 to 15 of 94
Thread: 4:77's & 35's...some stats...
Ldub 4:77's & 35's...some... 09/23/2011, 06:40 AM
LittleBeast THANKS!!!!! I will be... 09/23/2011, 06:52 AM
Ldub Yep, I'm experiencing some DL... 09/23/2011, 07:00 AM
samneil2000 You guys make me jealous. How... 09/23/2011, 07:04 AM
Ldub There is some down travel... 09/23/2011, 07:10 AM
BigSwede The rear 12-bolt is plenty... 10/05/2011, 04:44 PM
Ebenezr Your driveshaft and universal... 09/23/2011, 07:08 AM
Ldub Yep. Also, I re indexed the... 09/23/2011, 07:19 AM
Ebenezr YES understood. You do not... 09/23/2011, 07:37 AM
Triathlete Our 12 bolt rears are... 09/23/2011, 08:53 AM
LittleBeast My first thought was u joints... 09/23/2011, 10:20 AM
Ebenezr When you say "professionally... 09/23/2011, 10:36 AM
VXorado After a good conversation... 09/23/2011, 11:07 AM
samneil2000 What about those really low... 09/23/2011, 12:15 PM
LittleBeast Yes but the fronts 5.38's are... 09/23/2011, 12:59 PM
VXorado Right unless you do a SAS.... 09/23/2011, 02:48 PM
PK There ya go Mate, fixed it... 09/23/2011, 03:47 PM
nfpgasmask Weird, 7% is the number I... 09/23/2011, 03:58 PM
Ldub Yep...7.3% is what I get on... 09/23/2011, 06:31 PM
Triathlete Then when your done playing... 09/23/2011, 10:15 PM
Ldub If it crawls up ski jump,... 09/25/2011, 08:23 AM
BigSwede Yep, that's about right,... 10/05/2011, 04:47 PM
Ldub No worries Mate, I appreciate... 09/23/2011, 05:47 PM
rowhard so where did you finally find... 09/25/2011, 09:18 AM
nfpgasmask Aussie Lockers can be bought... 09/25/2011, 04:56 PM
Ldub There's a little back story... 09/26/2011, 06:13 AM
nfpgasmask Ahhhh, I see. For a minute I... 09/26/2011, 07:17 AM
tom4bren I think we did that with one... 09/26/2011, 07:29 AM
Ebenezr Did I understand this... 09/27/2011, 11:50 AM
Ldub Yeh...you heard... 09/27/2011, 04:10 PM
rowhard I called him on the day he... 09/27/2011, 06:18 PM
Ebenezr Ba ha ha ha ha ha. 09/27/2011, 08:33 PM
Ldub Thas an... 09/27/2011, 08:58 PM
tom4bren I have no response to that. 09/28/2011, 04:58 AM
LittleBeast Everytime I read this thread... 10/05/2011, 11:16 AM
nfpgasmask OK, so the VX has 4.30s with... 10/05/2011, 11:22 AM
Ldub :yesgray: Butt dyno feels... 10/05/2011, 12:03 PM
tom4bren So there's a significant... 10/05/2011, 12:15 PM
LittleBeast I would say yes. It is quite... 10/11/2011, 09:00 PM
nfpgasmask I know the difference is good... 10/11/2011, 09:27 PM
nfpgasmask BTW, I took this pic in my... 10/11/2011, 09:29 PM
BigSwede Bart, 4.56 to 4.77 is a 4.6%... 10/14/2011, 07:50 PM
BigSwede Whereas, for the VX, going... 10/20/2011, 08:43 PM
samneil2000 In other words, it's not... 10/21/2011, 06:16 AM
SilverBullet75 Ok. You guys got my... 01/27/2012, 12:28 PM
JoFotoz Your first issue will be... 01/27/2012, 12:34 PM
VXorado I'm installing 4.56 gears... 01/27/2012, 12:50 PM
Ldub Just reprising some answers... 01/27/2012, 05:57 PM
Maddawg http://i49.tinypic.com/5n43ko.... 09/28/2012, 03:51 PM
Ldub more gear thoughts 09/28/2012, 04:38 PM
SilverBullet75 I have 33's w/stock gearing. ... 09/28/2012, 06:42 PM
Maddawg Thanks SilverBullet! I just... 09/28/2012, 06:58 PM
yellowgizmo99 1. yes on front as well 01/27/2012, 12:33 PM
VXorado To clarify... Stock 4.30... 01/27/2012, 12:54 PM
Ldub Don't you mean DRIVE shaft... 01/27/2012, 05:32 PM
VXorado I was just testing you...... 01/27/2012, 05:59 PM
Ldub You have nothing to worry... 01/27/2012, 06:14 PM
BigSwede If the gears are already in a... 02/03/2012, 06:02 AM
LittleBeast I would have done this, but I... 02/03/2012, 11:41 AM
BigSwede Oh, and stock 245/70 = 29.5"... 02/03/2012, 06:07 AM
nfpgasmask So wait, you can move our LSD... 02/03/2012, 11:47 AM
Ldub You need to bolt the ring... 02/03/2012, 12:40 PM
nfpgasmask Hmmmm. :evil: Bart 02/03/2012, 02:06 PM
LittleBeast Yes, and not only that but I... 02/03/2012, 07:17 PM
Maddawg Who's not reading? My... 09/28/2012, 06:47 PM
Ldub Check the tude at the door... 09/28/2012, 07:58 PM
Maddawg :grino::grino::grino::grino::g... 09/29/2012, 08:11 AM
Ldub :smilewink...:flower: no... 10/11/2012, 06:15 AM
LittleBeast How did I forget about this... 10/12/2012, 04:10 PM
    Wrench 4:77's & 35's...some stats...
    Since getting my 4:77's & locker finally wrenched into the machine, I have had to re-calibrate all the associated numbers so that I can evaluate changes in mileage, odometer etc.
    First, I borrowed a GPS unit from my Boss & put a small dot on the lens of the speedo corresponding to 55-60-65-70 & 75 mph.
    OK, now I know how fast I'm really going.
    Next, I took a little 30 mile cruise, while my co-pilot, Hunny Girl, wrote down the beginning & ending mile markers, & the corresponding trip odo values.
    Then, crunched the numbers & came up with nearly 7% (6.94) margin of error.
    My old margin of error, figured the same way, was about 16% with the stock (4:30) gearing.
    My current rpm @75 mph is 2800.
    I will be updating this with my findings regarding mpg in the future, but my initial guess is that my mileage is getting better. As the fuel ga is moving to the left @ a slower rate @ previously known mileage values...
    Also, while maintaining a cruising velocity of 75 mph, I am experiencing neutral intake pressures, sometimes even slight vacuum, where before at the same speed, I was always under 3-4 psi boost. That's gotta help.
    For those trying to make sense of these convoluted calculations:
    The mileage on the trip odo will be multiplied by .07, that number is added to the miles on the trip odo, then that total (actual miles driven) is divided by the number of gallons used.
    2001, Ebony Black, 1153
    THANKS!!!!!
    I will be getting the 35's as soon as my 33's wear out (they have already lasted over 2 years and 60k miles), and since I already have 4.78's in front and rear this will help a lot!
    Do you still get the driveline vibrations? I have ordered the Indy4x lower links to correct the pinion angle after lifting to see if this fixes this. Thanks again for the info :-)
    Yep, I'm experiencing some DL vibe, especially @ 55mph.
    I know it's coming from the rear, because it was noticeable before I installed the front axle/driveline.
    I'll be very interested to hear your results.
    Feb 2009
    1999,silver, 1516
    You guys make me jealous. How are your CV boots holding up with maximum lift? Other than that, and some high angles on them, there's really nothing major going on. I wonder if the rear axle shafts are strong enough for the 35's and offroading - not to mention supercharging.
    Are your A-arms resting on the bottom stops or do you have a little space left for down-travel?
    Edit - Yall both have diff drop brackets, so your angles probably aren't any worse than mine... Crap, I need a bonus so I can go shopping for VX parts. haha
    Gear
    There is some down travel left in the front because of the ball joint flip & the addition of low pro bumps from Indy4x.
    I've seen more than a few posts here & there on the web that indicate the Isuzu corp 12 bolt compares in brawn to a Dana 44.
    Oct 2003
    1995 Isuzu Trooper LS
    The rear 12-bolt is plenty strong, I never had a problem wheeling with 35s. The front CVs are more of a concern, although a little sanity with the skinny pedal goes a long way.
    Sep 2010
    2000,Ebony,VEC,0013
    Your driveshaft and universal rotation is now faster at 55 (not that you didn't know this) so was there vibe before at 65??? oops you said it was noticable
    Wrench
    Quote Originally Posted by Ebenezr View Post
    Yep.
    Also, I re indexed the drive shaft/third member connection 180 deg, on the chance that it would help, but alas, not so much...
    The funny part of that is:
    I had backed into my parking spot (on a slight incline) & was about to proceed with the "laying on of the wrenches", when Marlins experience flashed into my brain.
    I then pressed the wheel chocks into service...
    Sep 2010
    2000,Ebony,VEC,0013
    Yep.
    YES understood. You do not want to be a human wheel chock. but U joints are noted for singing at 55 MPH.
    Our 12 bolt rears are actually stronger than a 44 and pretty close to a dana 60 iirc. They are getting popular with the dark side (jeep guys).
    My first thought was u joints with the vibration, but after having the driveshaft professionally rebuilt with new u joints and all and seeing no real lasting improvement, I am convinced most of the dl vibration after lifting is due to the new different angle of the pinion in the 3rd member side.
    As far as down travel goes I am the same with ldub with the ball joint flip and ultra low bumps on the front, so i do have some down travel left at rest, but you would be surprised to note that the first thing to make contact now is the bolts that connect the front cross member to the frame.
    Sep 2010
    2000,Ebony,VEC,0013
    When you say "professionally rebuilt" was your driveshaft rebalanced??
    After a good conversation with Matt from indy4x yesterday, I am reducing that extra lift I added last weekend for my new 35s and installing a 3" body lift to make up the difference. I have ball joints flipped, low profile bump stops & a 2" drop but to get the appropriate height you need to get close to max ifs down travel (about 4"). The body lift should give me some room in the wheel wells for 35s while leaving the suspension with some room to move. I'll let ya know how it goes.
    Oh and I'm jealous of those 4.77s dub & littlebeast. I just bought a 12 bolt with an arb locker & 4.56 gearing so I guess I'm giving up on finding those mythical 4.77s.
    Feb 2009
    1999,silver, 1516
    What about those really low 5.xx something gears that were being sold here a while back. They might be a good match for 35's...
    Yes but the fronts 5.38's are near impossible to find. You can get the rears pretty easily though. Those that have the 5.38 fronts tend to know that they can get a lot for them :-(
    And yes they did the high speed balancing when they rebuilt the driveshaft. Nice shop here in Houston.
  1. 2009 Moab Trip Stats
    By Kenny in forum VX Talk...
    Last Post: 05/26/2009, 06:59 AM
  2. General VX stats?
    By Kingler5 in forum VX Talk...
    Last Post: 05/02/2006, 04:11 AM
  3. Stats on VXs Produced by Color and Year
    By bumblebee in forum VX Talk...
    Last Post: 09/07/2005, 11:26 AM
  4. Some stats' on VX mileage
    By cascabel3 in forum VX Talk...
    Last Post: 07/20/2005, 02:19 PM
  5. Vehicle Theft Stats
    By TEN36VX in forum VX Talk...
    Last Post: 06/25/2005, 07:02 PM
