I have yellow and Red coming on my next batch
Green has yet to be availalbe
sorry. But black
goes with anything
To me, preventive maintance is key, and if you have
over 80k on your stock hoses, you may want to consider
putting these on prior to any leaking or bursting in the summer
while stuck in traffic etc.
An easy way to ruin an aluminum motor like ours is to overheat
it too much.
For the leaking syndrome, it could be your
hose or more likely
it could be where the plastic tank meets the aluminum..over time
they tend to split right there and will cause a leak, which will only
get worse over time.
As for installing them, if you are a little mechanically inclined and
have a few tools and an hour to kill, you can usually do it yourself.
Have a gallon of antifreeze around to be able to refill your system
when you are done and be sure to properly dispose of the old stuff
away from pets and a way thats good for the invironment
