For most all components to build your own lift start Here:
http://www.independent4x.com/
I've searched the forums best I could to get the following information. If you have an addition, please post your part, part number, and details regarding the part, and I'll add it to the original list.
Here goes...
--------------------- BEGIN LIST ---------------------------
Ready to run lifts
Calmini
independent4X
Rocky Road
Components
Energy Suspension
Sway Bar Bushings:
Greasable (zerk) 19mm = 355-9-5156R (G for Black instead of R)
Greasable (zerk) 28mm = 355-9-5163R (G for Black instead of R)
Low Profile Bumpstops: 9.913R or 9.9102R
Tie Rod Boots: 9.13101R
High Profile Rear Bumpstop: 9.9104R
Coil Spacer: Independent 4X 1" Independent 4X 2"
PROTHANE
Sway Bar Bushings:
19mm = 311-19-1118
28mm = 311-19-1144
Bump Stops:
Low Profile = 311-19-1319 (front)
4 1/2" High Profile = 311-19-1311 (rear)
Stinky Fab Joint arms
Extreme Duty Lower Links
Bilstein Shocks
Front - B46-1738-H2 (H1 option for more stiffness)
Rear - B46-1739-H1
FROM VEHIGAZ
"I installed these on my VX (H1's in front) a couple years back, and while they are an excellent choice for the VX with a very close-to-stock ride, the rears are probably stiffer than they need to be, and a softer one might be appropriate for the VX. After all, these Bilstein models are actually the ones they recommend for the Trooper (they don't have a recommendation for the VX), and the longer Trooper probably carries more weight on the rear axle, requiring a stiffer shock to counteract the additional inertia."
I ended up going with the Bilstein shocks, and I'm very happy*with my choice. H2s up front and H1s in the rear. I keep a heavy tool box in the rear, and from the front the rear shocks feel great. My rear seat passengers would argue that though... but I don't think anything will feel good to someone sitting directly over the rear axle.
Old Man Emu Rear Coils - OME912
Adjustable Coil Spacers
Small(0"-2 1/2")P/N: 91645551
Large(3 1/8"-5 1/4")P/N: 91645552
Available from Speedway Motors. (clickable links above)
Sway Bar disconnects: independent4X
Brake Lines: independent4X
See a trendindependent 4X has just about everything.
tie rods: Independent4X
Extended Brake lines also available at independent4X, ebay, and basically anywhere that has 4X4 Supplies.
---------------- END LIST -----------------------------
Needed:
Poly Spacer part numbers and links
Adjustable coil spacer part numbers and links.
Names of recommended supply houses for any of the above components.
Misc info:
Torsion cranks - 3-4 turns per inch.
Great thread on lifting
Lifting FAQ
Ball Joint Flip tutorial with pics
ball Joint Spacers - independent 4X
Drop Bracket threads:
http://www.vehicross.info/forums/sho...eferrerid=1999
http://www.vehicross.info/forums/sho...threadid=11230
